Old 08-22-2014, 06:50 PM   #1
kylexxkyle
kylexxkyle is an unknown quantity at this point
KA Choosing head gasket for my KA-T
This is my first engine build and I'm in a little over my head but I'm learning as i go. I am having trouble picking the right HG. I am building a KA-T and have super tech pistons 10.5:1 with eagle rods, arp studs, fully built head and got the head decked. I don't know exactly how much they decked the head but it was not extreme. I am planning on shooting for around 400 hp and have been looking at metal head gaskets. Help would be appreciated.
kylexxkyle is offline   Reply With Quote
Old 08-23-2014, 07:10 PM   #2
Chris28
Chris28 is an unknown quantity at this point
Can't go wrong with Cosworth.
Chris28 is offline   Reply With Quote
Old 08-23-2014, 07:23 PM   #3
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Cosworth is always a good choice
On my friend s14 ka-t with 390whp 410trq
We run a stock head gasket with o-rings in the block ... allmost two year of dayli driving and drifting nights !!! Still going strong
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 08-23-2014, 08:33 PM   #4
kylexxkyle
But as far as thickness would you recommend going thicker than stock with a shaved head and 10.5:1 compression pistons?
Old 08-23-2014, 09:13 PM   #5
rbs14kouki
rbs14kouki's Avatar
Just go thicker / safer and you will never have to look back
AV FABRICATION
Old 08-25-2014, 07:03 PM   #6
beavis360
beavis360's Avatar
beavis360 is making a name for him/her selfbeavis360 is making a name for him/her self
+1 for Cosworth HG but the block and head should be confirmed flat by the machine shop.
There are plenty of people running the felpro for under 400hp goals.
With that said, a turbo application at 10.5 is going to be a harsher environment in the chamber, people usually drop compression for turbo. The thicker HG will knock off a bit of compression which might be desired.
I've only heard of people running 10.5 pistons on e85 engines, is that what you'll be running?
beavis360 is offline   Reply With Quote
Old 08-25-2014, 07:22 PM   #7
waxball88
waxball88 is an unknown quantity at this point
Felpro, 3 years, 20psi, just dynod 400whp
Current new build is getting a cosworth
waxball88 is offline   Reply With Quote
Old 08-25-2014, 10:35 PM   #8
XMcEvilson
XMcEvilson's Avatar
XMcEvilson is an unknown quantity at this point
you got wrong compression ratio pistons for your goals
XMcEvilson is offline   Reply With Quote
Old 08-27-2014, 01:55 PM   #9
Sleepiedaze
Sleepiedaze is an unknown quantity at this point
running 10 pds of boost on a KA with OEM gaskets. tryed cosworth and they failed, did the cosmic aluminum crap and that failed. OEM all the way.
Sleepiedaze is offline   Reply With Quote
Old 08-27-2014, 03:09 PM   #10
waxball88
Then the issue was not with the parts it was with you either cheating out on machining. Or installing incorrectly
Old 08-27-2014, 08:46 PM   #11
Razi
Razi is an unknown quantity at this point
Probably had a surface that wasn't smooth enough for a metal gasket.
Cosworth will always lap the block and head until it becomes incredibly smooth.
Razi is offline   Reply With Quote
Old 08-28-2014, 03:29 PM   #12
Sleepiedaze
been building motors since i was 17 so ehh. just telling you from personal experience.
Old 08-28-2014, 04:11 PM   #13
Razi
Here's a good article on lapping engines written by Eric Hsu, a man who's worked at Cosworth for many years:
http://www.motoiq.com/MagazineArticl...eparation.aspx
Old 08-30-2014, 09:33 PM   #14
BoostSlideWayz
BoostSlideWayz's Avatar
BoostSlideWayz is an unknown quantity at this point
Send a message via AIM to BoostSlideWayz Send a message via Yahoo to BoostSlideWayz
Im personally on a ka24e i built. Arais pistons, eagle rods, lots of machine work including having my cyls bored just slightly beyond stock. Making it somewhere in the 2.4/.5 basically 2.5 and i've been running the stock head gasket for years. I peak around 16 psi before fuel cut. Never had to change it since i built the engine and never had any steam issues besides the usual warm up in cold weather type steam.
Car has been reliable and running strong.
Stock head gaskets usually are very durable. But then again with 400+ hp youll probably want an upgraded multi layer steel head gasket.
Also, are you planning on running E85 with that compression ratio ? If you plan on unleaded fuel ( pump gas ) your going to blow through just about any upgraded head gasket you buy.
1994 toyota supra...... n-a D=
1992 nissan 240sx KA24E-T fully Built =D
BoostSlideWayz is offline   Reply With Quote
head gasket, ka-t
