Old 05-12-2013, 11:17 PM   #1
aga
aga's Avatar
aga is an unknown quantity at this point
wrong rpm?
hey guys, a question! (no shit!) my car's rpm gauge (the dash one) started showing 500-1000 rpm more than real. i see on my commander that i have for example 1000rpm idle, and the dash says 2000...besides i can tell by the sound too. it happened before for a trip then straightened itself out. now here it is again. is it a cable , somewhere rubbing or something? i guess ecu to dash?
aga is offline   Reply With Quote
Old 05-12-2013, 11:22 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
its not a mechanical tach. the instrument cluster gets a signal from the ecu.
the ecu gets a signal from the distributor if you have a KA, but seeing as you're in greece you probably have a CA or SR? the SR and CA use a cam angle sensor (cas).
are you using a power fc?
Old 05-12-2013, 11:27 PM   #3
aga
aga's Avatar
i have an s14 sr , with powerfc. by cable, i meant electrical cable. (you're used to calling them wires, sorry)
Old 05-13-2013, 06:40 AM   #4
Sileighty_85
Sileighty_85's Avatar
Probably the gauge itself. Pretty common for S14s to do that.
You can reflow the solder points on the back of the gauge that the screw go into in hopes that fixes it.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-13-2013, 06:42 AM   #5
aga
aga's Avatar
so , a broken soldering point could be the cause? i'll check it.
Old 05-13-2013, 01:15 PM   #6
aga
aga's Avatar
driving home today i noticed a method to this madness...
the gauge rpm are twice the real ones!
1000 rpm = 2000rpm
3000, = 6000
my car is learning multiplication tables it seems.
Old 05-13-2013, 01:57 PM   #7
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Hopefully it does not achieve sentience anytime soon.
Sileighty_85 knows his stuff here, he pretty much started the discussion on Zilvia of fixing the issue rather then replacing the tach.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 05-13-2013, 02:20 PM   #8
aga
aga's Avatar
if it does , its gonna thank me for saving her from the previous owner. yeah its certainly something wire-related, im gonna look into it after work, if they let me leave some decent hour...
Old 05-13-2013, 07:21 PM   #9
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
I tried soldering mine and it does not work. My gauge is still at 2k everytime I turn my car on instead of 1k but it's not really that high.
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 06-09-2013, 11:35 PM   #10
aga
aga's Avatar
i removed the dash and resoldered everything behind the gauge.
i would say it did SOME difference,but not fixed it. now it sometimes works fine, sometimes x2 and sometimes something in between. i've noticed it jumping around while sitting at a traffic light. there's a big resistance behind the gauge, could it be knackered? should i try to replace that one? if that doesnt work i'm tossing it and replace it with a Koso motorcycle thingy, my mate's got one and it's excellent
Old 08-06-2013, 03:32 AM   #11
aga
aga's Avatar
found the cause of my woes. there's a plug near the ecu at the passenger footwell that was loose. when you wiggle that, the rpm's bounce all over the place. tie wrap remedy, all ok.
Old 08-06-2013, 03:44 AM   #12
Ayy_mo
Ayy_mo is an unknown quantity at this point
glad to hear
Ayy_mo is offline   Reply With Quote
dash, electrical, rpm, s13
