![]() Hello, I have a stock 94 180SX. I am currently interested in simply doing air intake, turbo back exhaust, and a better intercooler setup. I don't currently plan to try to get tons of power.
My concern though is I don't want to remove too much of the stock look of the car. Any suggestions for a FMIC (or beefier SMIC) that will accomplish little to no bumper cutting? Thanks! |
#5 | |
GM2 (SW/AW)
Don't be afraid of used stuff. just leak test it and return it if it leaks
KA-T for life! Current for sale advertisement ![]() |
#6 |
I built a backdoor style intercooler for my s14 with a 4" core if you look on my build thread you can find some photos. It requires that you use a narrower radiator and minor trimming to the core support (down low where you don't even see it)
#7 |
![]() Join Date: May 2002
S15 OEM sidemount is bigger than the RPS13 one and when they pop up on Yahoo Japan or UP Garage/croober they're usually dirt cheap. Swap over the piping and brackets and it bolts on, slight trimming to the duct to accommodate the added inch or so of core thickness.
#9 | |
#10 | |
Thanks! |
#11 | |
OP is looking for a low impact/bolt on solution for a low power car. |
#14 |
regular front mount with charge pipes painted black? All you have to do is trim the bumper cover and cut two circular holes on the chassis for the charge pipes.
even ka-t guys can pull a stock look with painted pipes. Looks way cleaner imo too. stolen from the sleeper ka-t thread: ![]()
Tuners are big bullies ![]() |
#15 | |
Here's one for 550 yen (four US dollars): https://www.croooober.com/en/item/cp...ler-Silvia-S15 Probably get better shipping rates from buyee or other yahoo auctions shipping service though: https://buyee.jp/item/search/query/s...nslationType=1 |
#16 | |
**Edit that's at least what Buyee is warning me about. |
#18 | |
The only thing is sometimes you have to fight with Buyee to get them to realize that an intercooler or whatever isn't a HAZMAT and let you buy it. They'll flag listings because of some random keyword and block you from bidding. |
#19 | |
#20 |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
The limitations for a side mount are more around cooling the charge temps and heatsoak than anything
![]() Best way to do business with me? Make your best offer FIRST. |
