Old 04-10-2020, 10:10 AM   #1
silviaks2nr
silviaks2nr's Avatar
2jz swapping my clean kouki after 16 years
After 16 years of ownership I did finally decide to bite the bullet. My car is a very good example of an s-chassis and the one thing that always kind of let it down was the engine bay- granted it was a pretty good KA-T setup, just tired and not up to par with the rest of the car. It was time for something else. A single turbo 2jz setup with paint matched bay and quality components should really help with that. Anyone who's been on here a while has probably seen pictures of my car "before", but here's a little refresher.
So I'm a pretty good ways into the swap at this point. The goal is to use quality parts and fabricate what I could myself- the intercooler, exhaust, charge pipes, etc. The engine is a jdm non vvti, stock internals, freshened up with studs and HG, BC 264 cams springs and retainers, new waterpump and timing components. Stock r154 trans, light flywheel, aluminum DS. Here's a few photos of the engine tear down and refresh. The engine covers will be painted closer to the end.
made a water rail without all the unnecessary nipples
pulled the ka
Next, I mock up the tucked radiator/condenser/IC core and trim a few areas, as well as patch the battery tray and corresponding area behind the DS headlight.
Up next painting the bay and dropping it in. Sorry if some of the vertical images are huge- trying to fix that.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-10-2020, 12:33 PM   #2
silviaks2nr
Originally I had planned to paint the bay gloss black since I may end up changing the color of the car in years to come, but after some deliberation green would really just look way better so green it is.
With clearance of the intake manifold being a known issue I installed chasebays lines and a new z32 master, plus they just look way better.
'98 240sx 5spd
Old 04-10-2020, 01:50 PM   #3
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Looks good but you should've hammered out some clearance on the transmission tunnel before paint. Now you're going to end up hammering fresh paint. Ask me how I know.
dbeiler is offline   Reply With Quote
Old 04-10-2020, 02:40 PM   #4
silviaks2nr
Maybe I’m way too anal, but I padded the hell out of everything in preparation to setting the engine in.
Success!
The excessive extended shifter housing still didn’t land the shifter exactly where I’d like it but it’s good enough- You’d think with the same company’s mounts and everything it would be a little more on point but it’s not. The engine could go back further IF I modified the trans mount, which I really don’t care to do. The upside is I have plenty of hood clearance and the extra room between the bell housing and tunnel makes it nice if and when I have starter problems.
'98 240sx 5spd
Old 04-10-2020, 02:43 PM   #5
silviaks2nr
Thankfully I was good, have decent clearance everywhere. Maybe the mounts I have make the engine sit lower? It's definitely further forward than most people do too.
'98 240sx 5spd
Old 04-10-2020, 03:59 PM   #6
BryanS14
BryanS14 is an unknown quantity at this point
Beautiful car and build!
2011 F150 DD, 1992 Mercedes 190e 2.6 Toy, 1997 240sx-sold
BryanS14 is offline   Reply With Quote
Old 04-10-2020, 05:06 PM   #7
s1421
s1421's Avatar
s1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the rough
In for this build!!
s1421 is offline   Reply With Quote
Old 04-11-2020, 12:37 AM   #8
AndrewS13
AndrewS13 will become famous soon enoughAndrewS13 will become famous soon enoughAndrewS13 will become famous soon enoughAndrewS13 will become famous soon enoughAndrewS13 will become famous soon enough
Following along. Clean car ��
AndrewS13 is offline   Reply With Quote
Old 04-11-2020, 11:22 AM   #9
greenmachine300zxtt
greenmachine300zxtt is an unknown quantity at this point
wow impressive bro. been following you since and great choice of motor swap
greenmachine300zxtt is offline   Reply With Quote
Old 04-11-2020, 12:35 PM   #10
silviaks2nr
Mounting the radiator, intercooler, and condenser. I know the Derale shroud is massively thick, but even so there is enough clearance to service the drive belt after it is installed. I want to be sure this thing stays cool. Cooling problems are always caused by people using cheap single pass radiators and mediocre fans.
'98 240sx 5spd
Old 04-11-2020, 04:05 PM   #11
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
^^ what are the radiator specs, thanks.
lewisfk is offline   Reply With Quote
Old 04-11-2020, 05:30 PM   #12
silviaks2nr
Radiator from PRC 23x13" and 3" thick, dual pass
'98 240sx 5spd
Old 04-11-2020, 05:32 PM   #13
silviaks2nr
Next I built a new fuel system. You saw in a previous photo I am using a radium rail and ID 1050x injectors. I installed a walbro single 525 in the tank along with 8an and 6an bulkhead fittings into the factory bulkhead (not pictured). I ran the lines on the drivers side and 3d printed some brackets to hold the lines and inline filter up nice and tidy. Pictured is another bracket I designed to hold the fuel and clutch line where they come up into the engine bay where a factory heat shield originally bolted.
Feed right off the back of the rail with a 8an banjo fitting
return off the front of the rail to the FPR- I?m not completely satisfied with this routing and I may change it.
'98 240sx 5spd
Old 04-11-2020, 07:48 PM   #14
greenmachine300zxtt
what is the spec on that condenser and what engine and trans u mount thanks ? loving this build
Old 04-11-2020, 08:41 PM   #15
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
I have always been a huge fan of your car man! Love the stock styling and cleanlyness of it. Can't wait to see the finished product once the swap is complete!
Cameron
speedfiend is offline   Reply With Quote
Old 04-12-2020, 11:13 AM   #16
-kenny-
-kenny- is an unknown quantity at this point
Looking good. Cant wait to see final results
-kenny- is offline   Reply With Quote
Old 04-12-2020, 01:54 PM   #17
silviaks2nr
Thanks y'all. Not sure on the condenser, I figured it out so long ago and don't have the box anymore. It's a generic one with integrated drier, approximately the size of the radiator (23x13)
'98 240sx 5spd
Old 04-12-2020, 01:58 PM   #18
silviaks2nr
Here?s about where we?re caught up, building the intercooler and charge pipes. It?s pretty straight forward so I will let the pictures explain everything. I haven?t seen many people do a back door intercooler setup on s-chassis, but It?s so neat and tidy, and with the narrower radiator I am able to go that route. The o ring?d male/female ferrules and clamps dress it up over standard silicone couplers and are hopefully less likely to leak.
'98 240sx 5spd
Old 04-13-2020, 10:31 AM   #19
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Looking good so far.
I've seriously contemplated ditching my KA-T in favor of something smoother and better sounding, like a JZ. I'm interested in seeing how you will compare the two setups when it's all done.
spooled240 is offline   Reply With Quote
Old 04-13-2020, 11:22 AM   #20
tuzzio
tuzzio's Avatar
I'm happy you already stated the engine covers are getting painted closer to the end. Everything is way to nice for them in their current state. Keep it up!. This build is awesome
Old 04-13-2020, 01:07 PM   #21
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Shit this is rad. Dude over here making his own intercooler. Assuming you are going to maintain ac and heat with this beaut?
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 04-13-2020, 04:42 PM   #22
Alan_s14
Alan_s14's Avatar
Alan_s14 is an unknown quantity at this point
Subscribed for more car porn
Alan_s14 is offline   Reply With Quote
Old 04-14-2020, 12:33 PM   #23
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
Wow man looks great. Keep it up
Old 04-14-2020, 01:44 PM   #24
silviaks2nr
Thanks! Yeah the plan is to have heat & a/c and I plan to do an electric power steering conversion as well.
'98 240sx 5spd
Old 04-16-2020, 02:18 PM   #25
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Spencer, Nice to see you've held onto it for so long and it still in very good shape
Enjoying the current refresh and upgrades
IIIXziuR is offline   Reply With Quote
Old 04-28-2020, 09:37 AM   #26
silviaks2nr
Building the downpipe. I will be recirc'ing the WG dump tube back into the downpipe but I need to let that marinate in my head to find the best routing for that.
Since I'm doing the opposite of what most people do (keep A/C but delete hydraulic power steering in favor of electric PS) I needed to retain the factory belt routing but just shorten it up slightly. I built an idler pulley setup that uses the cast iron PS pump bracket but uses a much smaller pulley and sits lower for better cold pipe clearance and a tidier appearance.
charge pipes are next
'98 240sx 5spd
Old 05-16-2020, 09:51 AM   #27
silviaks2nr
wrapped up the downpipe and WG recirc pipe.
Here's the intercooler piping. I decided to weld all the ferrules for the ends of the pipes from the inside for a cleaner look.
a 3" ferrule on a 2.75" throttle body means I had to sandwich a small piece of 3" od tubing between the ferrule and throttle body but it's hard to see unless you know to look for it.
'98 240sx 5spd
Old 05-16-2020, 10:16 AM   #28
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Wow that looks crazy clean. Great idea welding on the inside of those couplers
Sent from my iPhone using Tapatalk Pro
BiG MiKE86 is offline   Reply With Quote
Old 05-17-2020, 09:30 AM   #29
silviaks2nr
Thanks Mike!
DC integra radiator hoses? Ok.
'98 240sx 5spd
Old 06-09-2020, 08:42 AM   #30
silviaks2nr
Cerakoted the exhaust parts. This was my first time using this product, shot with the "glacier black" color.
I know the valve covers and coil cover look horrible! I'm getting to that soon.
I also 3d printed a small din housing to hold the AEM gauges. The bulky bezels look so out of place in a 90s car IMO.
The sound quality from the factory tape deck is not great, but I love the look, and for how much I use the car this should be just fine. I decided to convert it to bluetooth/hands free by hijacking the L and R channels from the tape deck.
'98 240sx 5spd
Copyright ©2000 - 2023, vBulletin Solutions Inc.
