Old 06-26-2023, 05:47 AM   #1
elepaqxon
elepaqxon is an unknown quantity at this point
bumper repair advice
Hey guys, just wanted to know what's the best way to repair a cracked bumper. I have a oem navan bumper that has a crack on bottom right. I know plastic welding it would be the best solution, but I don't know anyone who can plastic weld/has a plastic welder, and don't have the money to have it professionally repaired by a shop. I'd rather do it myself. I know some of you are gonna flame me and say "use the search button", I just need a quick answer from someone who's done it before. Thanks
elepaqxon is offline   Reply With Quote
Old 07-01-2023, 09:41 AM   #2
silviaks2nr
silviaks2nr's Avatar
Get a plastic welder and DIY. They are under $50. You can use the metal mesh to press into the back of the part to stabilize the cracks and then carve out and fill them from the front, then shape and smooth and paint. It's really not difficult to DIY
'98 240sx 5spd
kouki 2jz t56 swap build
Old 07-05-2023, 01:07 PM   #3
slider2828
slider2828's Avatar
Buy that and look at a couple of videos online.... really easy to do then you can bondo primer and paint.....
https://www.amazon.com/Plastic-Welde...83245793&psc=1
Turn and Burn!
