Old 09-08-2019, 08:34 AM   #1
Therealjs6
Therealjs6 is an unknown quantity at this point
Angry HELP!! Can’t fix shutting off issue
To start off. I have a 1992 Nissan 240sx ka24de 200,000 miles. Car ran perfect when I first bought it. 6 months later it takes a fail on me as I’m driving. One misfire then maybe 100 feet later shuts off and all the idiot likes come on. Doesn’t hesitate like it has no gas it just completely turned off no hesitation. I try to start it but it only cranks. I get a tow home and next day I go to to start it and it runs. I drive it for 5 minutes and same problem but with no misfire just shuts off and I have to wait a day to start it again. And now this happens everyday I can’t drive more than 5 minutes without shutting off. So far I have replaced the ignition control module , ignition coil , and spark plug wires. I ran the Ecu and got the codes 34,11,13 which are camshaft position sensor, coolant temp sensor, and knock sensor. Please help I am lost with what to do
Therealjs6 is offline   Reply With Quote
Old 09-08-2019, 01:26 PM   #2
Presto
Presto's Avatar
Presto is an unknown quantity at this point
My ka24 single cam will run high idle for 5 mins then kill itself and idk what it is
Presto is offline   Reply With Quote
Old 09-08-2019, 02:44 PM   #3
S14rebuild
Anyone check spark? Check fuel pressure?injector pulse?
Just thrown parts at cars doesnt usually fix the issue
Old 09-08-2019, 04:08 PM   #4
Therealjs6
Once it does there’s no spark and I’m pretty sure the fuel pump doesn’t turn on either
Old 09-08-2019, 05:48 PM   #5
S14rebuild
Check efi relay
Old 09-08-2019, 08:24 PM   #6
Kingtal0n
Kingtal0n's Avatar
"egi" relay
and get a multimeter from harbor freight tools $5 so you can check voltage at the computer during incidents
Old 09-08-2019, 08:26 PM   #7
S14rebuild
Originally Posted by Kingtal0n View Post
"egi" relay
Thanks
Old 09-08-2019, 09:00 PM   #8
Therealjs6
"egi" relay
How should I check. My codes that I pulled don’t mean anything u think?
Old 09-08-2019, 09:01 PM   #9
Therealjs6
Check efi relay
If it was the egi relay why am I getting no spark too
Old 09-08-2019, 09:05 PM   #10
Therealjs6
I don’t know if this has to do with it. But I put new spark plugs CAuse my old ones looked burnt and they idled for around 5 mins before the car shut off and even the new ones became very black. Not wet
Old 09-09-2019, 10:12 AM   #11
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
right, so you guys, if you are NOT getting spark, check the EGI relay.
make sure it is engaging. I've seen a number of Nissan ecus that fail, and will not trigger the EGI relay to engage.
Old 09-09-2019, 12:41 PM   #12
Therealjs6
Is there a way to tell if it’s bad
Old 09-09-2019, 12:56 PM   #13
brndck
brndck's Avatar
of course. if it clicks on and sends power past it, its good
if it doesn't click on and send power past it, its bad
if it does either of those things intermittently, its bad
want me to come help you brush your teeth too?
Old 09-09-2019, 01:02 PM   #14
Therealjs6
Wanna not be a cunt lmao
Old 09-09-2019, 01:19 PM   #15
brndck
brndck's Avatar
I mean, unless you wanna buy me a flight to philly, you're gonna hafta do some of this diagnostic work yourself. Go check your relays, get a test light or power probe or multimeter to check for power across the switched side of the relay, then next time it fails, check it again and make sure you confirm the results.
Old 09-09-2019, 01:25 PM   #16
Therealjs6
Thanks man lol I’ll check
Old 09-10-2019, 01:46 PM   #17
Therealjs6
I have work today so I only got to drive it for around 10 minutes but of course when I need it to die on me it won’t die
Old 09-19-2019, 01:24 PM   #18
Therealjs6
So the car shut off. And I checked the relay and power comes out
Old 09-19-2019, 03:20 PM   #19
Kingtal0n
Kingtal0n's Avatar
you need to put the $5 multi-meter on the ECU power / EGI relay output
and have the meter ready for when the engine shuts off
to verify the power is gone or not
if not, continue to use the meter to complete diagnosis by checking each circuit until isolated the problem
"shutting off" suddenly is likely:
1. 1 or more relays failing (replace relay indiscriminately)
2. fuel pump failing or sudden fuel filter clogging (check fuel pressure during issue)
3. fuses can be 'bad' suggest also changing fuses at 'random' (change the ones you think might be associated just for the heck of it)
4. loose wires, plugs, loose ECU connection, (check ECU plug, check ALL wires, pull on them while testing CONTINUITY with $5 meter
For #4 study factory service manual diagrams, follow the power from battery to the computer/injectors/distributor/etc... so you know instinctively which circuit gets power from where, when that power should be there, etc...
for example I believe the injectors receive a 12V constant supply (always even when car is shut off)
this and other simple 'intuitive' knowledge will aid diagnostics
make sure you
A. learn how to perform continuity tests using $5 meter
B. learn how to test for ground and voltage using $5 meter
Old 09-23-2019, 07:59 AM   #20
jedi03
how much coolant do you have in the system?
Old 09-23-2019, 08:00 AM   #21
S14rebuild
Why ask that^?
Old 09-29-2019, 06:33 PM   #22
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Not true. Sometime it can be bad connection from harness.
kennedy8383 is offline   Reply With Quote
Old 10-03-2019, 12:55 AM   #23
rosiereed
rosiereed is an unknown quantity at this point
please check the EGI relay.
rosiereed is offline   Reply With Quote
Old 10-03-2019, 08:13 AM   #24
jedi03
tried running a single cam that would do that...found out after my first 20 min drive with it headgasket was gone and there was no water in the system...but the diagnostic above looks pretty good too!
Old 10-03-2019, 11:35 PM   #25
Presto
Presto's Avatar
If one of my coolant hoses (under intake manifold) is kinked and not letting anything through could this cause the car to die? Also I noticed that my car only dies when I put it into gear, fuel pump maybe?
Ka24e SOHC
Old 10-05-2019, 02:55 PM   #26
S14rebuild
No^.............
distributor, ecu, nostart, spark
