Old 06-22-2019, 08:16 PM   #1
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
KA No oil pressure after head gasket replacement
Never had an oiling issues before. Oil light stays on and head looks dry save for the assembly lube. Oil at high mark on dip stick.
I'm stumped. Any suggestions besides pulling the engine and replacing the oil pump?
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 06-22-2019, 08:44 PM   #2
Kingtal0n
Kingtal0n's Avatar
hmmmmm
mess with the O-ring anywhere?
Wrong head gasket, or gasket on backwards?
Get an oil pressure gauge, mechanical, temporary on it as close to the oil pump as possible
not sure about KA
Old 06-23-2019, 01:17 AM   #3
wurley
wurley's Avatar
wurley is an unknown quantity at this point
I would pull the oil filter off and crank to determine if its the oil pump or something with the head. It's a messy, yet easy way to see.
I've had two no oil situations:
one was oil relocation lines backward
second was oil pan crushed against pickup tube, literally made zero oil pressure.
both were on sr's
@hiddenkouki
WTB: FRONT S14 SILVIA Q'S SEATS purple zebra)
wurley is offline   Reply With Quote
Old 06-23-2019, 01:53 AM   #4
Kingtal0n
Kingtal0n's Avatar
yeah sr20 also add pickup tube fell off,
pickup tube o-ring
Actually for LS engines pickup tube O-ring is also a thing
So is the cam gasket (in that area) but I digress
in any case always use mechanical oil pressure gauge to determine pressure,
never rely on electric or visual
and study the Oil-Flow diagram. It starts somewhere, and ends somewhere (rod bearing #1 area is where they end).
It will give clues about where pressure should appear first, second, third, and so on
Old 06-23-2019, 10:18 AM   #5
kingkilburn
Philosopher King
Pulled the oil filter and it was nearly empty. Obviously not getting any flow, nevermind pressure.
Took a peek under the car and the pan is domed up in the middle. Thanks to truck driver.
I'm goi beng to drop the pan, push out the dent, and hope that my pick up is fine. Will update when I know something conclusive.
Old 06-24-2019, 10:43 AM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
what motor? a new pickup is cheap. if its a redtop sr20, now would be a great time to upgrade to a blacktop pickup.
Old 06-24-2019, 05:09 PM   #7
kingkilburn
Philosopher King
It's an s13 KADE. Nothing special unfortunately.
Old 06-24-2019, 07:18 PM   #8
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Are you 100% sure you got an S13 KA24DE head gasket? The S13 and S14 headgaskets are slightly different...
Just asking the silly questions to check them off of the list here.
pics for reference;
S13
S14
They're inverted in the pics and I don't THINK would cause this but still...
NukeKS14 is offline   Reply With Quote
Old 07-14-2019, 03:38 PM   #9
kingkilburn
Philosopher King
Update of sorts.
Had to wait forever for a gasket separator to come on the mail. None of the parts stores knew what I was asking for, nevermind having it in stock.
Finally broke the seal, unbolted the pickup and brace. Now I can't get the pan out... I keep seeing people saying it comes right out but I have the worst luck with this cursed engine.
Old 07-15-2019, 07:37 AM   #10
jedi03
just use a putty knife to get in there! should be able to come right out lol, whats it stuck on?
Old 07-15-2019, 08:17 AM   #11
brndck
brndck's Avatar
How did you get the pickup off without removing the pan?
Old 07-21-2019, 07:41 PM   #12
S14rebuild
Unbolt the motor mounts and jack up the motor to get more space for the pan to come out, clear the rack and pinion and front subframe
Old 08-30-2019, 08:05 PM   #13
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
From what i heard the s14 head gasket can work on s13 Dohc motor. Sometime it could be bad install or somthing damage to cause no oil pressure.
kennedy8383 is offline   Reply With Quote
