Old 04-06-2014, 11:14 PM   #1
JDMBart
Banned from the Marketplace
Trader Rating: (-1)
JDMBart is an unknown quantity at this point
Feedback Score: -1 reviews
Is this normal?
I have a ka24de and have tried doing everything to get my idle down. Nothing seemed to work, but today I fabricated a bracket to pinch one of my air lines that goes to the intake manifold. Before my idle was at 1500 now I am able to adjust the idle as much as I please by turning the bolts. The current idle is at 900 rpm. Here is a picture, has anybody else had to do something similar to this?
JDMBart is offline   Reply With Quote
Old 04-06-2014, 11:24 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I'm literally laughing at the moment...
Old 04-06-2014, 11:25 PM   #3
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Why not find the real problem and fix it instead of make a band aid? Anyways this is pretty damn comical.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 04-06-2014, 11:29 PM   #4
JDMBart
Trader Rating: (-1)
problem seems to be that the car is getting too much air, closing this line up a bit fixed it and it runs perfectly
Old 04-06-2014, 11:30 PM   #5
KiLLeR2001
Trader Rating: (46)
You should tell people to ditch their IACV's and buy your new bracket system, it'll sweep the market by storm!
Old 04-06-2014, 11:31 PM   #6
JDMBart
Trader Rating: (-1)
i know bro
Old 04-06-2014, 11:32 PM   #7
zerodameaon
A band aid is not a fix, and you just stated what the issue was so there is where you should start. If you do decide to sell these how much are they going for and do you have a preorder?
EDIT: I know you want help, but you know the issue you have why not post about how to fix the problem instead of post this thing.
Old 04-06-2014, 11:46 PM   #8
JDMBart
Trader Rating: (-1)
IACV was cleaned and swapped out with new gasket , throttle body was cleaned and gasket replaced, tps sensor was replaced and adjusted, maf was tested/cleaned, new coolant temp sensor, new plugs, distributor cap and rotor. Problem was still not solved, ran out of ideas
Old 04-06-2014, 11:49 PM   #9
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
instead of throwing parts at the car...why not invest in a consult port link for $80 and plug into your car with a laptop... that plug is under your dash for a reason, just saying.
Old 04-06-2014, 11:55 PM   #10
KiLLeR2001
Trader Rating: (46)
Old 04-07-2014, 12:18 AM   #11
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Check the adjustment for the throttle stop, and the adjustment for the throttle cable itself.
Old 04-07-2014, 02:53 AM   #12
zerodameaon
Have you noticed a little something in all my posts? It may just fix your issue because in your long list of things you did not address the important one.
Old 04-07-2014, 10:07 AM   #13
JDMBart
Trader Rating: (-1)
My adjustment screw is all the way closed...
Sent from my SPH-L720 using Tapatalk
Old 04-07-2014, 11:55 AM   #14
scott883
scott883's Avatar
scott883 is an unknown quantity at this point
hahahahahahahahahahahahaahahahahhaahahahahahahah
scott883 is offline   Reply With Quote
Old 04-07-2014, 01:45 PM   #15
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Just because you cleaned and replaced the gasket on the IACV doesn't mean it isn't bad. Buy a full KA intake manifold from someone for 20 bucks and take the iacv off.
Old 04-07-2014, 02:06 PM   #16
zerodameaon
You must have missed the stuff past the adjusting the idle part. Set your timing and look for vacuum leaks, betting that is what you have.
Old 04-07-2014, 02:28 PM   #17
JDMBart
Trader Rating: (-1)
hooked up a vaccum gauge and the results were 18 hg so it came back normal, but I have not yet checked timing
Old 04-07-2014, 02:33 PM   #18
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
or just buy the IACV brand new...
Old 04-07-2014, 03:19 PM   #19
robinsone
robinsone is an unknown quantity at this point
Well here's a quick fix, how about you check the resistance on you IACV first. Find one of the FSMs online which are free, get a voltmeter and measure the resistance. If the resistance is out of spec, then replace with either a used or new one. Although if you do end up buying used, check the resistance first to make sure its good. Then install.
robinsone is offline   Reply With Quote
Old 04-07-2014, 04:19 PM   #20
JDMBart
Trader Rating: (-1)
good points, thanks dudes
Old 04-09-2014, 12:45 PM   #21
Hoffman5982
Trader Rating: (25)
Not everyone wants to drop that kind of money in the off chance that it's something else
Old 04-09-2014, 01:27 PM   #22
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
I dont even know what I just seen. Fabs bracket to pinch line. Cant properly check leaks. Im -22 on my vac gauge at idle
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 04-09-2014, 01:41 PM   #23
JDMBart
Trader Rating: (-1)
Maybe if you would scroll up and see that I did check vacuum leaks. I'm not looking for your commentaries
Old 04-09-2014, 04:24 PM   #24
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
You should get a turbonetics manual boost controller inline with the IACV to adjust your idle lmao
but seriously, there's a way to properly adjust the idle. Unplug the plugs near the TB there should be two. Start the car and let the idle stablelize after the engine is warmed up. Turn the adjustment screw on the IACV-this should be near the back of the intake manifold. Plug in the plugs and it should be lower.
spooled240 is offline   Reply With Quote
Old 04-09-2014, 05:03 PM   #25
jdhariwal
jdhariwal's Avatar
jdhariwal is an unknown quantity at this point
No, using a random peice of metal to restrict airflow on a line is def. not normal.
It's fucking retarded.
jdhariwal is offline   Reply With Quote
Old 04-09-2014, 07:53 PM   #26
zerodameaon
He has already gone through my walk through and it did not help him. He has issues elsewhere.
air, idle, intake, problem
