06-28-2011, 09:24 PM | #1 |
OEM head gasket vs cosmic 1.5mm gasket
So I have 2 SR20DET, one black top one red top, the black top is running fine but unknowen whats been done or if anything been done to it.
The other SR (the red top) has a blowen head, but bottom ends been rebuilt (new bearings and rings I think), so I got a new head (2nd hand seems good condition from inspection) and thinking of rebuilding it, I was thinking of using the red top in my project car (as it is without an engine). Ok so my aim is for about 320hp - 350whp just wondering if OEM gasket is good enough for this as the price differences is about $200, and since if OEM is good enough one of the engines are going to be sold anyways. so which motor should I use? and if I'm to use the red top which gasket? |
06-29-2011, 06:55 PM | #7 |
The OEM headgasket can easy take ~400whp. As long as you got cooling & detonation/pinging under control. Heat and bad mapping/tune is what kills the gasket.
My engine been pushing 334whp for 3 year now with OEM gasket, and shows no signs of weakning. Done plenty of trackdays. |
06-29-2011, 07:40 PM | #9 |
so one guy's engine holds a little over stock power says it can take it and you side with him?
You already have the engine out and almost apart might as well install an Apexi H/G for an ease of mind.
06-29-2011, 08:01 PM | #10 |
Trader Rating: (105)
Feedback Score: 105 reviews
I run a OEM head gasket at 15psi on a t28 daily, I wouldn't push it past that though. If you want to go past that I would recommend Apexi or Cosworth like mentioned. Cometic is garbage! Mine leaked at 10psi.
PM me for s13 or s14 parts! |
07-02-2011, 09:46 AM | #11 |
Trader Rating: (58)
Feedback Score: 58 reviews
ApexI or Cosworth. Make sure you get the head/block resurfaced as well.
07-04-2011, 01:54 AM | #13 | |
Banned from the Marketplace
cosworth is cometic with a cosworth stamp
garage boso has tested every head gasket out there and this is there results Quote:
07-04-2011, 10:05 AM | #14 | ||
Trader Rating: (58)
How recent is that test? Cosworth didn't develop their new headgasket for SR20 (including their large bore) until 3 yeras ago or so. Eric Hsu's blog (beyond the dyno) had a huge writeup on the creation of it (which I can't find now) but I did find this update on Moto IQ: Should You Change Your SR20DET Head Gasket? > MotoIQ > Magazine Articles Quote:
Cosworth wouldn't ever copy a Cometic gasket in this day and age.
07-04-2011, 10:08 AM | #15 | |
Trader Rating: (58)
And for those looking at this, here is a great article for you all on head/block prep...all to often people skip this step, and it ends up being a cause of failure:
Deck Preparation > MotoIQ > Magazine Articles Quote:
07-04-2011, 10:15 AM | #16 |
This right here is a true statement. Why the hell would a company that's been in racing for six decades imitate a company that's been in business since the late 80's? They have no reason to and it would be blasphemy and a disgrace to the Cosworth name and heritage. They are a leader in their field.
07-04-2011, 11:11 AM | #17 | |
Trader Rating: (58)
With that said however, I know early on in the large bore SR world there were issues with companies not making a decent big bore gasket, and that's why Cosworth went ahead to develop one (IIRC they may even make a 92mm one, but don't quote me on it)
07-05-2011, 07:19 PM | #18 |
Stock S13 SR HG doing just fine here with no issues. I have maybe 4000-5000 track miles on the stock engine at this point, always run at 1 bar with a GT2876R or GT2871R with 93 octane. On the street it always sees 18 psi, and it has had about 1000 miles of 21 psi on E85 (made enough torque to slip my ACT HDSS clutch repeatedly in 4th).
That said, I'd go with a Cosworth HG. I can't believe someone said it was a Cometic copy. What a crock... They don't even look remotely similar. Here's a pressure plot of a stock vs. Cosworth HG on an SR: I'll give you 3 guesses as to what POS gasket is on the bottom, and two don't count... More info: Cosworth Big Bore Head Gaskets for Sleeved Blocks > MotoIQ > Magazine Articles
07-05-2011, 07:38 PM | #20 |
I would rather see independent studies rather than Cosworth (Eric Hsu) trying to promote their head gaskets.. As far as I know, Cosworth is a completely different company from what it used to be back in it's glory days..
07-05-2011, 09:05 PM | #21 |
Don't know much about the other brands but i do know that enjuku racing uses cometic on there drift cars and im sure they are pretty beefed up cars just my 2 cents
Taken from enjukuracing.com-Cometic 1.01 Metal Head gasket Nissan SR20DET... "This is the same headgasket used by our two Formula D drift cars running 11:1 compression with ~21 lbs of boost"
07-05-2011, 09:22 PM | #22 | |
Eric Hsu seems to tell it like it is even if it goes against whatever is putting the bread on the table for him. I'll give him respect for that. I see cars have HG sealing issues all the time with Cometics personally, and honestly stock SR gaskets aren't half as horrible as you'd believe reading the dumbasses that detonate theirs to death on Nissan forums.
07-05-2011, 09:32 PM | #23 |
my friend is runing a OEM head gasket on is sr20VET ... it was a 650whp at 28psi mustang dyno last week !!!
exemple of what i did to is block !!! 572Ci Mopar Wedge Engine Build O Ring Scribing Photo 4
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
07-05-2011, 11:41 PM | #24 | ||||
Trader Rating: (58)
Cometic on an F1 car? Show me where. I hate to sound like a nutswinger, but Eric Hsu and his blogs are notorious for being honest, and fair. He's got all the time in the world to test his reasoning, we don't. Quote:
For 90% of the forum, stock HG on a good tune is plenty fine. THe rest of us already know better. VE have factory metal head gasket.
07-06-2011, 04:02 PM | #25 |
i run a 3071 at 20 psi for the last year and half (over 12 000 km) with a stock head gasket. checked compression after a year(8000 km) and it was 153-147 across the board. i plan on building the whole engine when its time to open up the engine not just fortify the head.
07-06-2011, 05:49 PM | #26 | ||
And for the record, I run a simple Fel-pro head gasket in my built KA running 20+ lb's of a boost with a gt35r... Whether or not Cosworth is a good brand is irrelevant to me since they don't make parts for any engine I have or that I'm interested in.. (KA, 2JZ, or LS1).. |
07-06-2011, 05:59 PM | #27 | |
You're trying to make it seem like we're putting words in your mouth, but you're the one taking a jab at their integrity as a company putting out quality products.
07-06-2011, 07:33 PM | #28 | |
If I really wanted to take a jab at their integrity, I would talk about how they sold their engineering division to Audi more than 10 years ago, or how the entire company was sold I don't know how many times, or how a few years back nobody even wanted in them in F1.. But once again, I don't think they are a bad company, I just don't think they are as good as they used to be.. I believe they do a lot more R&D than a lot of these stupid knockoff and "JDM tyte" companies nowadays. But like I said before, I don't trust comparisons from companies trying to promote their own products... It's so easy to skew the results to make your stuff look better if no third party no involved... And why are you guys getting so worked up about this? It's just my opinion and point of view.. I could be dead wrong and they could better than ever now.. If I'm wrong about anything let me know, I like learning new things.. |
07-07-2011, 03:59 AM | #30 | |
This sounds like the jury deliberation in the Casey Anthony trial. OK you lied to the police!
