Old 12-24-2009, 01:57 PM   #1
cumbewong
cumbewong is an unknown quantity at this point
Send a message via AIM to cumbewong
2 way or 1.5 LSD?
I've searched but I haven't really quite found the answer I'm looking for.
I basically want to know which is better to DD with, 2way or 1.5?
-less tire wear?
-less oil management?
I know that 2way performs better for drifting, but I drift every here and there. And I know that 1.5 will do the job just fine.
cumbewong is offline   Reply With Quote
Old 12-24-2009, 02:00 PM   #2
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
open diff is good for dd
weld is not bad for dd
go 1.5
killer240 is offline   Reply With Quote
Old 12-24-2009, 02:02 PM   #3
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
-less tire wear?
You pretty much answered your own questions. haha. Open diff is best for daily, but shitty for performance.
2 way is great for drift and daily, but is really noisy. 1.5 sounds like it suites you best.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 12-24-2009, 02:08 PM   #4
cumbewong
yeah, its just really hard to decide.
so 2way you have to change the oil more often right?
2way
change oil often
makes more noise
good to dd
excellent for drifting
1.5
good to dd
not as much noise
good for drifting but not as good as 2way
i don't really mind the "noise" so i think i'll go with 2way? ahhh idk! LOL
Old 12-24-2009, 02:16 PM   #5
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Any clutch diff youll have to change the oil more often than others, it doesnt really matter if its 1.5way or 2way.
LayNLow is offline   Reply With Quote
Old 12-24-2009, 02:17 PM   #6
s13gebala
s13gebala is an unknown quantity at this point
ull start minding the noise when ur cars clunking around parking lots
s13gebala is offline   Reply With Quote
Old 12-24-2009, 02:59 PM   #7
g6civcx
g6civcx's Avatar
The noise goes away after proper break-in and about 5k miles. Using the correct fluid also helps a lot.
Old 12-24-2009, 08:36 PM   #8
tkocrewsr
tkocrewsr is an unknown quantity at this point
2way is full lock on accel and decel
1.5way is full lock on accel and partial lock on decel
I got a carbonetic for quite operation and i am more of a road race guy,but any diff does recommend often fluid changes.
tkocrewsr is offline   Reply With Quote
Old 12-24-2009, 08:39 PM   #9
240sxfamily
240sxfamily is an unknown quantity at this point
weld your diff, cheaper.
240sxfamily is offline   Reply With Quote
Old 12-24-2009, 11:03 PM   #10
ericcastro
ericcastro's Avatar
1.5 for you.
if you drift pretty rarely, then i will assume you lifting means you want to exit a drift before a spinout or you hit something.
a 2 way wont let you out of a drift as fast as a 1.5
Old 12-24-2009, 11:56 PM   #11
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
I have a nice tomei trax advance diff, it's a 2-way and extremely aggresive. It's set to full lock and it was DD as well as tracked. I mean if your creating a great drift car build to compete with, i would go 2-way, otherwise just simply do 1.5 way. You won't really need much more if your not going to go crazy with it and compete and such.
But if you do decide to go with a 2-way, PM me and I'll give you a good price on the Tomei.
DataXUnknown is offline   Reply With Quote
Old 12-25-2009, 12:37 AM   #12
Black_Demon
Black_Demon is an unknown quantity at this point
the open diff. is a really good daily driver. i use to run that until people kept telling me about bumps...
as of right now, I am currently running on a welded diff.
but correct me if i am wrong, but i have heard some of my friends who drive with a open diff. and it is lowered and some slammed and pretty stiff, and they sometimes get stuck on driveways, bumps, etc. where they had to get some help to push their car. This they say is due to the open diff. having only one tire spin.
has that happen to you guys yet?
Black_Demon is offline   Reply With Quote
Old 12-25-2009, 03:06 AM   #13
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
With subframe spacers, and solid motor/tranny mounts you can't even tell my car has a diff. If you can't dd a car because the diff makes a little noise then don't drive a modded car, get a Cadillac.
HYPNOTIK is offline   Reply With Quote
Old 12-25-2009, 03:22 AM   #14
cumbewong
Originally Posted by ericcastro View Post
1.5 for you.
thankyou. so i've decided to get a 1.5. what's brand do you guys recommend?
Old 12-25-2009, 03:39 AM   #15
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
go 1.5 way.
2 way, you might as well do a welded diff
2 way clunks like a motherfucker around turns my buddy had a kaaz 2 way and its pretty loud around turns.
S13 curtis is offline   Reply With Quote
Old 12-25-2009, 03:50 AM   #16
DriftReady_S14
DriftReady_S14 is an unknown quantity at this point
Yes, this has happened to me a few times. One scenario is I was dropping off my girl to work and as I pull to the drive way slowly cuz my car is pretty low but not as slammed as most on here, the wheel that had traction was up in the air so I got stuck and couldn't reverse or go forward. I had to get out the car and push it.
DriftReady_S14 is offline   Reply With Quote
Old 12-25-2009, 07:03 AM   #17
smelly240
smelly240's Avatar
my kaaz 2 way is clunky and loud and poppity pop poppity pop.
it locks ultra hard tho.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 12-25-2009, 09:27 AM   #18
g6civcx
g6civcx's Avatar
1.5 for you.
Best advice in the whole thread.
Lifting on a 2way is just about the same as yanking the handbrake.
Old 12-25-2009, 10:29 AM   #19
Dousan_PG
Dousan_PG's Avatar
I far prefer a 1.5 way for drifitng
it feels fantastic
flybert drove my car, he's changing to it now
and azndoc loves his 1.5 way as well!
I use a cusco
flybert tomei
azndoc os giken
Aaron
Pink GodziRa
Old 12-25-2009, 11:27 AM   #20
ericcastro
ericcastro's Avatar
it feels fantastic
I use a cusco
flybert tomei
azndoc os giken
/thread
and to the guy somewhere above in this thread,
yes, open diffs can get stuck when a car has coils and tries to angle up a drive.
BTW, i ran a VLSD for a year.
Hooks as the drag guys say.
Good take off speed.
Drifts pretty good and will let you out when you lift.
doesnt chatter on corners.
will let you maintain corner grip during autocross.
i would rather have a 1.5 2way, but if the economy gets you,
VLSD is great for daily.
Old 12-25-2009, 11:35 AM   #21
articdragon192
articdragon192's Avatar
So question... how do you pull out of a drift with a 2 way lsd?
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 12-25-2009, 11:42 AM   #22
ericcastro
ericcastro's Avatar
im on a welded, lol
lift, clutch in, fingers crossed ??
just guessing
i think you get used to how early you need to lift and get the car weight coming back
Old 12-25-2009, 12:01 PM   #23
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
it feels fantastic
I use a cusco
flybert tomei
azndoc os giken
I have a OS Giken 1.5way as well. It is by far the best diff I've experienced ever! It virtually makes no noise and is like driving around on an open diff until you either clutch kick it or mat the gas. My car feels extremely stable in wet weather, I feel like I can grip drive it easier, but I drift my car and it is wonderful with that too.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 12-25-2009, 12:47 PM   #24
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
it feels fantastic
I use a cusco
flybert tomei
azndoc os giken
i have a kaaz 1.5 way, i love it for drifting and grip driving. great control from them while drifting as well.
NMs14.5kouki is offline   Reply With Quote
Old 12-25-2009, 12:53 PM   #25
Dousan_PG
Dousan_PG's Avatar
drifting is just car control
depends on the situation and your car setup
i think 'pulling out of a drift' is easy but ive been driving for some time. im no expert but it depends on whats going on and how fast your going, angle, etc etc
Aaron
Pink GodziRa
Old 12-26-2009, 11:41 AM   #26
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
after having a kaaz 2 way i switched to a carbonetics 1.5 and i much prefer the 1.5 way.
the lockup is less aggressive and i feel it allows me to have a smoother style when drifting. the carbonetics one also clunks less than the kaaz one did and the life of the clutch plates is longer than the kaaz unit also.
i would recommend 1.5 way unless its a track only car. just my .02
Old 12-26-2009, 12:36 PM   #27
!Zar!
!Zar!'s Avatar
I've only run welded and 2way, so I can't comment on the 1.5, but from what it seems like, all the "pro" drifters run 1.5 like the Falken cars and what not. So I'll probably end up trying it out to see what all the hype is.
Old 12-26-2009, 12:46 PM   #28
BlitzRPS13
BlitzRPS13's Avatar
BlitzRPS13 has a little shameless behavior in the past
Truth.
I have a nismo 2 way... really agressive and clunks like crazy around sharp corners when i'm going slow.. but it locks up super fucking hard when i want it to. I don't really care about the noise... just like my osgiken clutch.. super noisey but you learn to appreciate the sounds of a car like this as you always know what's going on.
BlitzRPS13 is offline   Reply With Quote
Old 12-26-2009, 02:58 PM   #29
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
im running a nismo 1.5 and its way better than a vlsd and open for the street. not as noisy as a welded when i had one but you do feel it lock on acceleration. stick to 1.5 or vlsd for the street and some track.
lilrusty is offline   Reply With Quote
Old 12-26-2009, 03:44 PM   #30
nathanong87
nathanong87's Avatar
i personally run a kaaz 2way, it clunked, it locks hard, does it's job i suppose. never used a 1.5 way, so i can't compare them, but i'm not dissapointed with a 2way in any way.
natelife.tumblr.com
1.5 way, lsd
