Old 03-13-2023, 08:02 PM   #1
Dsmturbo
Dsmturbo is an unknown quantity at this point
240sx with 2jz spring rates
What everyone running for spring rates?
Dsmturbo is offline   Reply With Quote
Old 03-27-2023, 08:51 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
every single human in the history of cars is using 8/6
anyone who tells you otherwise is a dang liar.
(before everyone gets all butthurt, /\/\/\ is sarcasm)
spring rate will depend on what you plan to DO with the car.
setups vary greatly between a drag car, a stance queen, an autocross/track car, or a D car.
Old 03-27-2023, 09:29 AM   #3
silviaks2nr
silviaks2nr's Avatar
8k 5k fa 500
'98 240sx 5spd
kouki 2jz t56 swap build
Old 03-27-2023, 11:07 AM   #4
AKADriver
AKADriver's Avatar
Will also depend what you do with the rest of the car weight wise. Going by the specs a 2JZ-GTE should weigh ~100lb more than a KA. Lots of ways to make that difference up.
Best to just get the car weighed. And not sweat it too much since spring rates usually only increment in whole kg/mm.
And off the shelf 8/6 coilovers are already way more front-biased than stock suspension which was like 2.0/2.0. Motion ratios are close to even f/r with stock geometry.
Old 04-05-2023, 03:51 PM   #5
Kingtal0n
Kingtal0n's Avatar
What is the factory S14 spring rate and where do you get a stiffer than stock spring
tinyurl.com/4l80er
Old 04-05-2023, 05:06 PM   #6
slider2828
slider2828's Avatar
I am also thinking going 8/6 on track but with a stiffer sway bars..... but lemme get on track with my megan racing w/ swift (10/8) and torrington bearings vs my new feal 442s (8/6) also......
Turn and Burn!
