06-21-2016, 11:53 PM | #1 |
Sr20vet vvl head shimming
I'm in the process of re-shimming my head before i start her up!!
I took down all the measurements with a feeler gauge on both the smaller lobes on the cams and this is what i came up with. NOTHING could fit in between the cam lob on intake side rocker #4. so now, i measure each shim, and order accordingly right? Where do i order shims from? Also what are the correct specs / measurements ?? i have Crower dual springs, with n1 cams. |
06-28-2016, 10:24 AM | #3 |
I directed him to Nick at 5523 motorsports. Mazworx would probably have a good idea of the shin height too.
06-28-2016, 10:40 AM | #4 |
Trader Rating: (130)
Feedback Score: 130 reviews
Shingo at Bluemoon did my engine assembly and shimmed my p11 head.
06-29-2016, 12:15 AM | #5 |
Nick at 5523 was EXTREMELY helpful. I HIGHLY recommend him, he actually took the time to thoroughly explain the process and specs.
07-02-2016, 03:03 PM | #6 | |
07-02-2016, 04:05 PM | #7 |
From memory when we did mine it was about 10-14 thou on the intake and 11-15thou on the exhaust with a rocker ratio of 1.6
I ordered harley davison shims as they were way cheaper, came in 0.05mm increments. I assume your measurements were taken with your existing shims? |
07-02-2016, 05:52 PM | #8 |
This is a great idea, but if you do so, please put it in the SR20 thread in chat.
07-03-2016, 02:38 AM | #9 |
IN : 0.08
EX : 0.12 This whole process was HELL. Shes finally shimmed and ready to be hooked up though!!!! |
07-11-2016, 01:06 AM | #10 |
Fuck I have done this a few times. It sucks when you had head work done, when I shimmed mine they were all over the place. I went to the Harley Davidson dealer and used the V-rod shims. You can also look buy a the hotcam shims to use.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
07-11-2016, 01:38 PM | #11 |
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
07-22-2016, 10:05 AM | #12 |
rbs14, i hope those aren't the correct specs.
Those are way off of what i set up head up at. it calls for IN : .17mm EX: .37mm i set mine at IN : 0.08 EX : 0.12 |
