Old 08-21-2016, 10:35 AM   #151
TheRealSy90
TheRealSy90's Avatar
The everything cd009 swap thread.
It's not janky though. The Speedtek kits work extremely well and there's a championship winner that's ran one for over a year now with 0 issues. Just because it doesn't look so pretty doesn't mean it's not functional.
Such a good signature.
Old 08-22-2016, 07:36 AM   #152
Croustibat
Originally Posted by japslapsilvia View Post
Auto Bellhousing from the motor you are adapting to, IE SR- SR Auto Housing. Are the bolt patterns the same for SR/CA?
I think the gearbox side of the bellhousing is identical. Engine side is not. CA & SR are quite common here (s13 come stock with a CA, S14 with an SR) .
The flywheel is also different, as the SR has larger clutch area (i was told it can be installed using an S12 starter ).
I'll try to get some more infos. Thanks.
Old 08-29-2016, 09:34 AM   #153
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
I have yet to install my cd Trans in my s14. Who is running the collinsplate and how much hammering was needed?
RickS14 is offline   Reply With Quote
Old 09-05-2016, 10:19 PM   #154
t66-240
t66-240 is an unknown quantity at this point
Originally Posted by jackal264 View Post
this looks super janky to me.
the collins kit (the cut + middle plate) looks way better to me then this option. now if collins would get off his ass and make a plate compatible with the j3 housing we would all be golden. seems like everyone has a j3 housing kicking around but the j1 is far more rare.
He does have one now. I think I got the second plate after the tester. The J3 is taller so the adapter is thinner requiring some notching of the J3 bell housing to clear the slave cylinder.
I'll update once I put it in. I'm using the collins motor/trans mounts too.
t66-240 is offline   Reply With Quote
Old 09-10-2016, 11:20 AM   #155
t66-240
I just started my 2JZ VVTI / CD009 swap in my s13 using Collins new adapter and J3 bell housing. I think he said mine was the second J3 adapter after the test one. here some pics.
Old 09-18-2016, 09:19 AM   #156
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 09-19-2016, 05:26 AM   #157
Joobie610
Joobie610's Avatar
Joobie610 is making a name for him/her selfJoobie610 is making a name for him/her self
Food for thought?
S15 spec gear needed.
Again, an Australian company. Have bought most of the TAARKS branded parts that suit my needs and they're all top notch. Might be worth seeing what a 370 box goes for?
Sent from my E6653 using Tapatalk
Joobie610 is offline   Reply With Quote
Old 09-19-2016, 06:56 AM   #158
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Rad to see taarks jumping in. All their products are top notch, and thoroughly sorted BEFORE release, unlike other companies who send you a part, then you have to send it back cuz it needs to revised or replaced.
Z34 Trans is comparable in price (in my experience) BUT I'm still wary of the internal hydraulic release bearing; I've read plenty of stories of them leaking badly. Sucks since you have to drop the Trans to change one out. I still have never heard of any advantage to using the internal one either.
Old 09-19-2016, 07:24 AM   #159
TheRealSy90
Originally Posted by Joobie610 View Post
Food for thought?
Some people figured out with the offset of the s15 6sp style flywheel, it's easier to get full spline engagement when using an adapter plate.
If you go with the Mazworx bellhousing, it retains the sr20 fork, pivot and bearing, even on concentric/internal slave transmissions. Good option if you want one of those trans.
Old 09-19-2016, 10:10 PM   #160
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
What air gap (clutch to bearing) are you guys seting up your set-up !!! On our racecar with internal release bearing we have it set a 0.200inch would it be the same for a fork set-up
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 09-19-2016, 10:12 PM   #161
TheRealSy90
With an OsGiken twin disc, they say to set it up with a 7-8mm play between the bearing and pressure fingers, to allow a bit of expansion room for when the clutch beds in.
Old 09-26-2016, 11:36 AM   #162
t66-240
Here is where my trans sits with the Collins new adapter and his engine/trans mounts. For final placement it may go a half an inch or so back.
It looks like the this is the best shifter for the 240. There is a group buy to get it down to $185.
http://cbfperformance.net/store#!/Gr...egory=19722030
It will perfectly center the shift lever although it will still require some cutting.
Old 09-27-2016, 10:15 AM   #163
t66-240
Here's where my trans sits with the new collins adapter, motor and trans mount.
It's about 1.5 inches from the firewall. I'll probably move it back another .75 to 1 inch back.
Old 09-27-2016, 10:39 AM   #164
rbs14kouki
rbs14kouki's Avatar
We went with 0.300inch for the air gap . My good friwnd did this for two of the z33 swap he did and they work perfect
AV FABRICATION
Old 09-27-2016, 02:07 PM   #165
Yellow4g63
No pic, might want to try photobucket to host your pic.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 09-27-2016, 02:34 PM   #166
t66-240
hmm. strange I can see it. I'll try.
Thanks!
Old 09-27-2016, 02:39 PM   #167
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Thanks!
Well if you can see it.
I guess we will just all come to your house.
Haha. Jfwy
lok is online now   Reply With Quote
Old 09-27-2016, 02:58 PM   #168
t66-240
Haha. Jfwy
Can you see it now? I'm using google photo from my cloud back up. Didn't know I had to move it to a shared album first
Old 09-27-2016, 03:35 PM   #169
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Looks about the same location as mine, don't get a gktech relocation, it wont work, Either a CBF or a Serial 9 shifter should do the trick.
I'll be swapping from the gk one and going with the CBF this winter.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 09-27-2016, 04:47 PM   #170
TheRealSy90
Originally Posted by Nissansota240 View Post
Looks about the same location as mine, don't get a gktech relocation, it wont work.
GkTech shifter works fine for mine and many other people's swaps. Both with the mazworx housing and with adapter plates.
Old 09-27-2016, 05:47 PM   #171
t66-240
Depends on the swap. with the 4 cylinder (KA, SR's) the engine doesn't sit as far back so many of these adapters work without cutting.
With in a inline 6 (2J, RB) space upfront is at a premium for cooling fans so the motors are typically sit much further back than with a 4cyl.
So while some of these shifters may locate the shifter near the stock location, you will still have to cut for the tower that comes out of the trans.
the only exception I've see with CBF's mid-mount set up which he discontinued due to high cost... around $650.
The pro-series CBF that is currently being tested may not require cutting as he has lowered the tower height. This may allow the tower portion of the shifter to sit under the trans tunnel and only have the shift lever stick out above. This is still being tested and about 2-3 months from production.
FWIW.
Old 09-27-2016, 06:56 PM   #172
TheRealSy90
Okay well the gktech was never advertised to be used with straight six engines anyways. And CBF has another shifter that goes on the inspection plate of the trans that would probably work better anyways.
Old 09-27-2016, 07:01 PM   #173
t66-240
Unfortunately not. see pic below. it's way too far forward for the s13/s14.
Old 09-27-2016, 07:17 PM   #174
TheRealSy90
That Picture hasn't worked for me this whole time so might be why it went over my head lol.
Old 09-28-2016, 12:49 AM   #175
Tearlessj
Tearlessj's Avatar
Is this the picture you can't see?
http://imgur.com/M2SpGyZ
What flywheel/clutch are you running t66-240? I don't want to pay what they're asking for the 350 clutch flywheel.
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 09-28-2016, 02:34 AM   #176
t66-240
Collins custom flywheel and a 350z disk and plate.
Old 09-28-2016, 07:18 AM   #177
Nissansota240
They may not advertise it as that but it is a z33 shifter, but that's why I said if anyone is running a I6 engine paired to a z33 trans to maybe choose a different shifter over gktech. Not because of quality or anything, just configuration. the amount of cutting to get it to fit, then with the shifter in reverse it almost hits the center counsol on the s14, granted I have my JZ pushed as far back as possible though. If you are not running interior I guess its not the end of the world for the location, but for me, I want to have the plastic bezel and shift boot placed back on and to have a somewhat OEM look.
Sorry for how terrible these photos where, but I only snapped them quick during the haste of trying to finish the car before an event.
DLG - DIRTYLOVE
Old 09-28-2016, 10:24 AM   #178
RickS14
RickS14's Avatar
Any body running Collins plate how much hammering was needed is it the same as a t56 ls1 combo?
Old 09-28-2016, 03:31 PM   #179
fatduece
fatduece is an unknown quantity at this point
Could you guys explain how you make the adjustment? The Tob sleeve comes in different sizes. I thought all you need is the correct SLEEVE, which OSgiken provides.
fatduece is offline   Reply With Quote
Old 09-28-2016, 06:36 PM   #180
TheRealSy90
That's exactly it, you order specific sleeves to set the depth of the throw out bearing.
And if you need a finer adjustment there's a place in the U.K. Called RB Motorsport that has thin spacers that press on the sleeve behind the bearing. But probably not necessary unless you're very particular.
