02-09-2017, 06:55 AM | #542 |
S13. Circuit Sport poly mounts.
Didn't move it front or back any but it does sit a little lower than normal.
My S13 SR Street Mod Build |
02-09-2017, 09:08 AM | #543 |
Trader Rating: (36)
Feedback Score: 36 reviews
S13 has a flat firewall, CAS clears it. S14 has a bulge where the sensor cap sits. RHD s14 and s15 firewalls are different than the LHD cars so there aren't any clearance issues. That's why the custom CAS cap is need or firewall modification has to be done to make it fit on a LHD car.
02-09-2017, 09:20 AM | #544 |
Hey guys so as seeing that this is only a LHD S14 issue, is there actually a market for producing them? Preferably we'd like to sell the first batch as a group buy so if there's interest we'll look into it.
02-09-2017, 09:41 AM | #545 |
Trader Rating: (36)
I'll be the first to sign up and yes I think there is definitely a market for them with a little advertising (making sure people know you make them!). I'm also pretty sure that the clearance on RHD s14 and s15 firewall is pretty tight with Nismo motor mounts and could definitely benefit from a modded cap as well.
02-09-2017, 09:46 AM | #546 | |
02-09-2017, 10:20 PM | #547 | |
02-10-2017, 04:12 AM | #549 |
Guys, i don't understand how the P12 billet cap will make any difference. I've measured my P12 cas and cap, and there's only 1 or 2mm play between the pickup and the inside of the cap. Sure some parts (around the disc) can be a bit more compact, but the pickup is the part that is going to stick out most so you'll end up with that part just as tall as OEM
@hanzbrady If you're opening a group buy, I'm definitely in for a piece at $40
Need UKDM/EUDM/JDM/RHD Nissan parts? Hit me up Insta: skids14 |
02-10-2017, 11:21 AM | #551 | |
Trader Rating: (63)
Feedback Score: 63 reviews
+1 ........... |
02-10-2017, 11:33 AM | #552 |
Hey guys, so we're open to the idea, and we can hit a price point between $40-60 assuming we get a good size group buy. If anyone has a P12 CAS they could bring by or ship out for RnD we could get started on it.
02-10-2017, 12:50 PM | #554 |
02-10-2017, 02:44 PM | #556 |
02-16-2017, 10:35 PM | #557 |
I'm not running pistons with valve reliefs at the moment, will I need to use P11 cams or stay with the stock P12 cams on a P12 head.
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
02-17-2017, 11:24 AM | #558 |
P11 cams only. You'll need piston with reliefs to go any larger.
02-17-2017, 11:48 AM | #560 | |
Either way, if you have it apart and the engine is on your stand, just spend the extra 1 hour or so to clay it up. It you skimmed both the head and block (which is required), you may also think about degreeing the cams. |
02-17-2017, 02:33 PM | #561 |
Greddy DE 87mm pistons but I don't recall the compression ratio. I believe it was 9:0:1 correct me it I'm wrong. It's been almost 15 years since I had this motor. But I'm looking to scoop up a short built block for this build.
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html Last edited by s13silvia123; 02-17-2017 at 04:11 PM.. |
02-17-2017, 04:48 PM | #562 |
Then anything is available. I'd personally run JE DET at 8.5:1 on a pump gas motor. That'll give you roughly 9.3:1 static with a factory 1.1mm HG. You could drop down to a .9mm and gain a couple tenths in compression. Once you near the 10:1 mark, you really need some type of alternate fuel or octane booster (i.e. Meth injection).
02-17-2017, 04:56 PM | #563 | |
Trader Rating: (130)
Feedback Score: 130 reviews
needless to say I ditched them for cp VE pistons with valve relief notches. I'm not saying you CAN'T run p11 cams with non-relief pistons, I'm just saying +1 for clay it. |
02-19-2017, 03:50 PM | #564 |
I am running cp stroker pistons without valve reliefs and n1 cams. To get the clearance I used a thicker head gasket a cometic 1.5mm. Based on the calculations my compression ratio is at 8.7:1. And everything has been clayed and clears.
02-19-2017, 11:14 PM | #567 |
My tuner with the 1/4 mile world record for sr20 powered irs s-chassi is running a 4 counter weight crank in is sr21vet .
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
02-19-2017, 11:15 PM | #568 |
Nagisa ou nagasi if im not mistaking
02-20-2017, 05:06 AM | #569 |
They are Nagisa Shakitto plates.
02-20-2017, 08:00 AM | #570 |
What about those who are running P12 cams without valve reliefs. are you guys clearing when properly clayed.
