10-23-2005, 12:15 AM | #1 |
OBD I to OBD II conversion?
Im about ready to buy the Greddy Turbo kit for my 95' 240, however im pretty sure i need to convert my OBD connections. Has anyone done this, or is there a specific kit out there to make this easier. Thanks
10-23-2005, 12:52 AM | #3 |
um you dont have to convert to obd2 that would meana you would need all the lil sensors wiring harness and ecu which would be completly pointless. Like stated above explain your reasoning
www.alabamagz.com http://www.cardomain.com/ride/2093248 |
10-23-2005, 11:07 AM | #4 |
The reason is because he wants to install the GReddy turbo kit which says its designed for the 96-98 S14 (OBD II). To the original poster, you don't have to convert to OBD II to a make this kit work.
10-23-2005, 11:41 AM | #5 |
Yeah like SimpleS14 said, i want to install the Greddy Turbo Kit in my car. I couldnt see any reason that the Kit wouldnt work, or why they said it wont work other than the OBD stats. Does anyone know why this kit was made for the 96 -98 models and not the 95... and what would i have to do, if anything, to make this kit work for me.
Thanks |
10-23-2005, 01:38 PM | #7 | |
10-23-2005, 01:47 PM | #8 |
Well, I wasnt too worried about the hardware fitting, i was more worried about the software not working right. The kits comes with the Greddy E-manage system, which you have to solder into your ECU. Im not very familiar with OBD I or II so i wasnt quite sure if i would have any problems with soldering the E-manage system into a OBD I car. I appreciate the help.
10-23-2005, 05:05 PM | #9 |
EManage suppposedly plugs right in with a socketed harness.
10-23-2005, 06:09 PM | #10 |
Thats what i thought, however i read the installation manuel from Greddy and it says to solder in wires (Page 15). I honestly cannot see why this wouldnt fit, however i'm most certainly not an expert in the field of 240's or turbo's so i just wanted some other peoples input before i plunge 3+ grand into my car.
I suppose it could be one of those little mistake that the big companies make... and as a result i get confused. (bastard companies ) Thanks for the help guys. |
10-24-2005, 12:39 AM | #11 |
OBD II sucks ass. Don't do anything! One of the main differences between An OBD I and II system are the use of a second O2 sensor on the back side of the cat. The reasoning is that the O2 sensor before the cat will read engine output, and the one on the back side would read how your cat is working. On these measurements, the ECU would attempt to change your perameters to make the engine run at its most efficient, well at least to the engine because of stricter emissions. If you put an OBD II system on that thing, the computer would keep trying to change everything that you were doing to the engine. Very annoying when you spend allot of money, and get no change. However with an e manage, that would probably not be the case. Still....... don't do it!
Women are like Turbos, the more they blow, the faster you go! |
10-24-2005, 01:19 AM | #12 |
OBD II does not suck. What the government uses it for makes it suck. There is a lot more to OBD II than the catalyst efficiency monitor.
"If you put an OBD II system on that thing, the computer would keep trying to change everything that you were doing to the engine." - WTF are you talking about?!?!?! Some people don't know their ass hole from a hole in the ground... much less how cars work Anyway, if you have any doubts, contact the manufacturer and ask. Its possible that the OBD II ECU has a different architecture and the pinout may be different. If the engine management kit comes with a connector specifically designed to mate with the OBD II ECU, you may encounter problems. Just contact the manufacturer and make sure.
2000 Volvo S70 GLT SE 2005 Volvo S40 2.4i MT 1993 Nissan 240SX Coupé |
10-24-2005, 08:49 AM | #13 | |
Your brain must be a black hole. All S14s have a rear O2 sensor, OBDI and OBDII. The 'main' difference is the EVAP canister design, and the change to a standard code system. The ECU could care less about how many turbos you've got as long as it's seeing what it needs to see.
10-24-2005, 09:40 AM | #14 | |
10-24-2005, 09:54 AM | #15 |
I know someone with a Greddy turbo kit and VSPL front mount intercooler.
DIRECT PLUG AND PLAY! Just a PITA installing the manifold. Because the stud barely clears the manifold, you have to work the bolt in there. Other than that installation is cake. Your bumper support wont fit, unless you trim the hell out of it. Also, your car will see stalling issues because there's no bov+recirc. |
10-24-2005, 08:49 PM | #16 | |
10-24-2005, 08:56 PM | #17 |
Hehe... aside from the argueing, thanks guys. I did contact Greddy but have yet to receive a reply. I think i might try calling them. Its good to hear about somebody elses experiances with the Greddy Kit. I really appreciate your help. I suppose i will just keep OBD I and try to make the kit work... and hopefully it was just a mistake made by Greddy about the compatibility with the earlier S14's.
10-25-2005, 05:38 AM | #18 |
Pearl White Mike
closebyu your thing says youre in japan, there is NO OBDII in japan to my knowledge.
oh yeah and the reason greddy doesnt offer it for the obd1 car is because of the cost of carb certification. getting that carb EO is extremely expensive and because the vast majority of s14's are obd2 compliant, they would end up paying double to test and certify a minority of cars. and (ive been told) that it works just fine there are just a couple of wires left over when installing the emanage on an early s14
"He who makes a beast of himself gets rid of the pain of being a man" ~ Samuel Johnson |
10-25-2005, 09:48 AM | #19 | |
The carbon canister pulls fuel vapor from the tank and reburns it, however the EVAP canister is a little more advanced in that it's not a constant draw from the tank, and it's controlled by the ECU directly.
10-25-2005, 11:14 AM | #20 | |
last i heard they were still pending? i could be wrong, though. |
10-25-2005, 05:04 PM | #22 |
Pearl White Mike
yeah but pending is good enough not to get a costly repair order in california
10-25-2005, 10:48 PM | #23 | |
No more nissan.
AHAHAHAHAHA closebyu26 owned by Russ! hah the best part is that in his own words:
10-27-2005, 01:45 PM | #24 |
Finally... Greddy replied to my Email. This is what they said...
"Thanks for your interest in GReddy performance products. The only thing that keeps the turbo kit from working with your car is the factory ecu. The fact is that your vehicle is OBD1 and the programming for the e-manage was for an OBD2 vehicle. In order to get the kit working you will need to make some changes to the base map settings in order to get it to run." Since im really not familiar with the Factory map setings, how would i go about changing those.. and i thought that the E-manage changes those settings anyway. |
