Old 01-15-2024, 07:06 PM   #1
roland
roland's Avatar
roland is an unknown quantity at this point
s14 240 s13/s14 clean out
240sx part out
NRG Harness bar $150
$250 - S13 Front Knuckle Set x 3
$300 - S14 Front cut Knuckle Set
$350 - S14 Silvia Front Knuckle Set (Dust shields are for 300zx style brakes)
$40 - S13 or S14 Front Brake Dust Shields (both styles available)
$30 - S13 or S14 Rear Brake Dust Shields
$300 - S13 Rear Subframe
$50 - S13 or S14 Front OEM Swaybar (both available)
$50 - S13 Rear OEM Swaybar
$150 - S13 Rear Lower Control Arm Set
$150 - S14Rear Lower Control Arm Set
$25 - S13 RUCA Set
$25 - S13 Toe Arm Set
$25 - S13 or S14 Traction Rod Set
$100 - S14 Rear Uprights
$125 - S13 or S14 Rear Axle Set
$50 - S13 or S14 E-brake cable set (both styles available)
$30 - S13 Rear Subframe Brace
S13/s14 rear disc brakes set
28 mm brake calipers black
2X tension rods
S14 gauge cluster with 165,000 miles
S14/S 13 tension rod brackets
S14 stereo bezel
roland is offline   Reply With Quote
s13 240sx coupe, s14 240sx coupe
