Old 12-13-2023, 11:59 AM   #1
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
s14 Cold start issue. S14 silvia sr20det
Can anyone give me a place to start with my cold start issue? Bone stock s14 silvia with an auto trans. Thinking vacuum leak and/ or coolant temp sensor. It vibrates at idle as well. https://youtube.com/shorts/VB21PWZUK...jWzQ5Orlq5P_xe
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline   Reply With Quote
Old 12-13-2023, 04:59 PM   #2
inopsey
watched the video, whats the issue? it starts fine
Old 12-13-2023, 10:27 PM   #3
240Zfunahollic
It really stumbles to start. Almost dies out then picks up to cold idle. Watch again with good volume.
Old 02-10-2024, 02:35 AM   #4
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
start by pulling the idle valve off and cleaning it. I'm sure the injectors have never been cleaned (do that if available local if not run a can of "cleaner" through them).
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 02-10-2024, 09:02 PM   #5
240Zfunahollic
Thanks for the input. After doing some digging I found a vacuum line and the factory diverter valve weren't fully connected into the intake. It's better but not 100%. But my fuel pump died last week and I suspect weak pressure didn't help. Replacing the pump when it comes in and will cleaning the IACV and looking for more vacuum leaks.
Old 02-21-2024, 10:10 AM   #6
240Zfunahollic
New fuel pump solved the issue.
