Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > Europe
Europe A place for our cousins from across the pond
Old 10-04-2023, 04:36 PM   #1
NCR
NCR is an unknown quantity at this point
5 Lugs swap S13
Hi, I'm from Italy and I got a 200SX RS13, like most of S-chassis guys around Europe. I want to do a 5 lugs swap because I have bought other wheels. What kind of set do you use? I was thinking about the ones from 240SXconversions, but I'm not sure. Are there better option here in Europe?
NCR is offline   Reply With Quote
Old 10-05-2023, 09:34 AM   #2
Thursday7
Thursday7's Avatar
GKTech front conversion hubs with quality (Timken, SKF) bearings pressed in + used Z32 rears is the cheapest "high quality" setup you can get. Being in EU shouldn't make this too difficult.
I got the 240sxconversions ones for my fronts in a pinch recently and have no complaints, but the car basically only sees ~10 drift days a year and little to no street time so I'm not overly concerned short-term.
Old 10-06-2023, 02:12 PM   #3
NCR
I was also thinking about Ichibas. Are they fine, right?
Old 10-09-2023, 01:56 PM   #4
Thursday7
Thursday7's Avatar
I've never owned any. From what I remember, they were kinda the go-to like 12 years ago: before Contano, ISR, etc. saturated the market. I honestly don't remember if they were regarded as high quality, they were definitely the most expensive option other than going new OEM S14 fronts w/ knuckles and balljoints and OEM S14/Z32 hubs pressed in the rear.
Old 10-11-2023, 02:46 AM   #5
NCR
I've read that the kit uses OEM bearings, while others don't.
Old 10-16-2023, 12:28 PM   #6
wezurii
wezurii is an unknown quantity at this point
I would just do what Thursday7 said, I to have the gktech and s14 hubs laying around
Only need to install the bolts and let a bearing get pressed in the gktech ones, then they are ready to go
wezurii is offline   Reply With Quote
Old 10-16-2023, 02:04 PM   #7
NCR
Yeah, I know, but S14's option isn't plug and play like others, sadly.
Old 10-16-2023, 11:48 PM   #8
wezurii
s14 rear just bolts in right up
Old 10-26-2023, 12:11 PM   #9
MattPym
MattPym is an unknown quantity at this point
If you take a look on Ebay Kleinanzeigen in Germany, there is a guy in east germany (Japartnese) that makes 5 stud hub conversion kits for S13s.... CNC machined and use standard bearing sizes. The price is pretty good, like 300 Euro if I remember correctly.
No need to change of to S14 stuff to run them
Will be ordering a set myself over the next couple weeks for my own car.
MattPym is offline   Reply With Quote
