Old 09-04-2023, 11:38 PM   #1
TheVinylKingz
TheVinylKingz's Avatar
TheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura about
Setting Ignition Timing on SR20DET
Not a tuner or professional mechanic.
When checking the ignition timing on the SR20DET, the timing has always been jumpy and never steady at 15+- degrees. Is this normal?
Mechanical timing 0 degrees TDC and CAS has been aligned correctly.
S13 SR, S14 KA
TheVinylKingz is offline   Reply With Quote
Old 09-05-2023, 05:55 PM   #2
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
smh its bc ur cheapass keeps changing parts on the sr without retuning
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
Old 09-05-2023, 08:08 PM   #3
inopsey
check your tps voltages, closed and open throttle and make sure its holding steady voltage at idle. should be about 0.45v at idle/closed throttle
Old 09-05-2023, 11:31 PM   #4
TheVinylKingz
Thumbs up
Thanks for the feedback. I will check the TPS.
S13 SR, S14 KA
Old 02-10-2024, 02:40 AM   #5
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
stock ECU? haven't had to deal with that in a long long time but you need to lock the timing (may have been as simple as unplugging TPS but check the factory service manual.) Once the ECU locks timing it won't jump around when you use the timing light.
Same exact process on standalone ECU's you just lock the timing at the value of choice in the software for the timing sync.
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 02-15-2024, 10:20 AM   #6
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
This is a fairly old post, but in case someone finds it in a search:
You have to lock the timing in order to check it. Process for that is fairly simple. Fully warm up the car, best if you can drive it around for 10-15 minutes. Turn off all accessories/lights/hvac/etc. Shut off engine. Unplug the TPS connection, then restart the engine. Rev it to 2k twice and then let the engine settle. It should now be locked on timing and you can check & adjust with a light as expected.
If you have a consult cable and software (like NDSI or similar) there's an option to lock the timing that way, but warm engine-unplug TPS method has worked for us for many years at this point.
Old 02-15-2024, 11:07 AM   #7
AKADriver
AKADriver's Avatar
Also needed for setting the base idle.
