Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > Europe
Europe A place for our cousins from across the pond
Old 09-08-2020, 07:10 AM   #1
Dustyx77
Dustyx77 is an unknown quantity at this point
The blow off valve issue
Hey guys, sooo I've bought a 200sx (eurospec) s14 that used to run on 24psi of boost, but the blow off valve, atleast according to the internet, is rated for 26psi. Sooo long story short, the car has still some major compressor surge sounds. I barely use full throttle because I use the car on the street. What kind of psi blow off valve spring would you guys suggest?
Dustyx77 is offline   Reply With Quote
Old 09-13-2020, 06:39 AM   #2
S14rebuild
If ur getting surge then the bov isnt opening or its too small.
First check your vacuum line to it. Should be a direct feed from intake manifold to the bov, not "teed" off another line.
Then make sure it acually opens, not stuck or damaged.
Old 09-14-2020, 10:48 AM   #3
TheRealSy90
TheRealSy90's Avatar
Your bov is probably set stiff so that it only fully opens if you were at full boost, and anything under that when cruising around it just stays closed.
Such a good signature.
Old 12-16-2020, 09:27 PM   #4
Kingtal0n
Kingtal0n's Avatar
The correct type of bypass for a turbo will hang open at idle, like the stock bov.
The best thing for the turbo is to be able to instantly relief any air, from using a very easy to open bov style.
The reason people don't like to use the correct type of bov on their cars is often because they do not have a recirculated bov style.
In other words, you need the bov to recirculate the air back to the intake (pre turbo) just like FACTORY does, or else, the maf will dump extra rich fuel into the engine whenever the bov opens.
I suggest looking at the factory bov setup, the bypass style. See if you can get a BYPASS style bov. For example greddy type-s was a bypass style bov.
Always put the bov as close to the turbo as possible. Never put it after an intercooler either.
If you get bypass style bov, you can use a very easily to open bov, so the turbo will never be in *pain*.
If you cannot get the bypass style, then the best alternative solution (used to be) is HKS SSQV placed right near the turbo (within 1-2 feet or so). It won't open at idle and it will cause a little surge (a little delay to open) but it won't cause MAF issues when vented to atmosphere much either.
tinyurl.com/4l80er
