Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > South Eastern States
South Eastern States Alabama, Florida, Georgia, Mississippi, North Carolina, South Carolina, and Tennessee.
Old 06-17-2020, 04:51 PM   #1
tjdionson
tjdionson's Avatar
tjdionson is an unknown quantity at this point
car all of a sudden won't crank over.
Car: 1996 240sx with s13 sr20det
Issue: Out of the blue my car won't turn on. I was troubleshooting a squealing belt, so I was turning the car on and off several times. Thought it was my power steering belt, but finally figured out it was the alternator belt all along. Made adjustments, turned it on, but squealing was still there so I turned the car off then tightened the belt a bit more. Tried to turn the car on and nothing. After trying several times, all electrical power was gone.
Things I checked:
-Fuses
-Bought new battery
New battery in, same issue. Have power when key is in "on" position and confirmed power to ecu. When trying to start car, I only hear a single click and if I do this multiple times, I lose all power. I have to disconnect the negative terminal to the battery wait a couple of minutes, then power comes back on. I'm at a lost, so any help would be greatly appreciated!!!!
tjdionson is offline   Reply With Quote
Old 06-18-2020, 11:17 AM   #2
tjdionson
tjdionson's Avatar
Anyone have any ideas?
Old 06-18-2020, 01:00 PM   #3
kablam
kablam is an unknown quantity at this point
Sounds like your alternator is bad.
kablam is offline   Reply With Quote
Old 06-18-2020, 05:26 PM   #4
tjdionson
tjdionson's Avatar
Anybody know correct size of s13 Sr20det lower alternator bolt?
Old 06-19-2020, 12:39 PM   #5
S14rebuild
Loose ground strap/bad cable. The one that bolts to the alternator bracket....check it.
Old 06-19-2020, 01:39 PM   #6
tjdionson
tjdionson's Avatar
Yes, you are right.. bad ground and have to check my battery cables. Thanks!!!
240sx, ignition, s14, sr20det
