Old 04-09-2020, 10:07 PM   #1
Fitelite240!!
Fitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-known
OEM+ -S15 Spec R braces in S14
I began acquiring all the oem jap Spec-R braces about a year into owning my s14. Being new and wide-eyed to the s-chassis platform I was bold and stupid. I was fascinated about having them and using them rather than getting a cage.
This thread is to display what doesn't work and what does, without too much headache.
So we have these that came from factory on the top tiered Spec-R s15's I'm sure they came on a few other models, I'm just not 100% sure: - Keep in mind. All these braces are a bolt-on affair for the S15 chassis.
Spec-R - Front ladder brace
Spec-R - Rear subframe brace
Spec-R - Roof Brace
Spec-R - Trunk Brace
Spec-R - Trunk Triangles
Spec-R - B-Pillar braces
Spec-R - A-Pillar plate braces
Spec-R - C-Pillar plate braces
Spec-R - Front Strut Braces Plates
Spec-R - Rear Strut Brace Plates
Spec-R - Rear Subframe brace
Here's how it fits on a Spec R - https://ibb.co/rc2QqMg
Here's how it can fit on an s14. - https://ibb.co/xqQCB8r
How can we make it fit in an s14? Very easy bolt-in affair. Just don't use the s14 subframe bolt plates the brace replaces those plates.
Spec-R - Roof brace
Here's how it fits on a Spec R - https://ibb.co/CQgjjRY
Here's how it can fit on an s14. - https://ibb.co/7XFmMLz -
https://ibb.co/KWdzZs5
How can we make it fit in an s14? Don't - Use the factory bolts with the Moonface roofbrace. Otherwise you'll cut into your good metal roof and cut into a rare-ish piece.
S14 roof factory bolts holes - https://ibb.co/0Bxtqv4
https://ibb.co/phrVPMy
Moonface roof brace - https://ibb.co/0nPJpdY
https://ibb.co/YDfhD7w
Here's how it fits on a Spec R - https://ibb.co/7YB0qHB - https://ibb.co/R0Gj5Rb
Spec-R - Trunk brace
Here's how it fits on a Spec R - https://ibb.co/23RTMC4
Here's how it can fit on an s14. - https://ibb.co/3p6XLBk
How can we make it fit in an s14? An easy bolt-in affair with our own Zilvian Bernie(Nova) making spacers in conjunction with hardware for the brace.
Here's how it fits on a Spec R - https://ibb.co/DGR1fHF
Here's how it can fit on an s14. - https://ibb.co/C1H3CHb -
https://ibb.co/tzZhzF3
How can we make it fit in an s14? With a drill, couple bolts, washers, and a hammer. Just make sure you drop your gas tank first before drilling otherwise you'll have a whole other headache. Also make sure the bolts aren't too long to rub against the gas tank when re-installed. Some light massaging of the trunk sheet metal will be required to flatten it for a flush bolting surface.
Here's how it fits on a Spec R - https://ibb.co/10VMSmZ
Here's how it can fit on an s14.- https://ibb.co/pvGvd30
https://ibb.co/D54pjwv
https://ibb.co/tcFQBMq
https://ibb.co/s2jPWnY
How can we make it fit in an s14? Don't - unless you are planning to have no rear seats. If the rear seats aren't used and the car is going to be a designated track car of some sort you can cut the plates and body to fit. But, these are not a bolt-in affair and will be in the way of the interior panels and seat bolt mounts if you plan on running those oem s14 pieces.
Spec-R - A-Pillar Plate Brace
Here's how it fits on a Spec R - Not Pictured
Spec-R - C-Pillar Plate Brace
Here's how it fits on a Spec R - https://ibb.co/WfJZxH2
Here's how it can fit on an s14. - No picture
How can we make it fit in an s14? - There's no way this will fit due to the body being a different shape.
Spec-R - Front Strut Plate Brace
Here's how it fits on a Spec R - https://ibb.co/XzxCfvC
Here's how it can fit on an s14. - Sits on the top of the top hat when installed from under in the wheel well.
How can we make it fit in an s14? Easy drop on plate to the coilovers or strut.
Spec-R - Rear Strut Plate Brace
Here's how it fits on a Spec R - https://ibb.co/yhpz2ST
Here's how it can fit on an s14. - I truly don't see these fitting at all. How they are shaped it would need cutting
How can we make it fit in an s14? Don't, get a rear strut bar of some sort which would do the same thing while aiding in rear rigidity.
I'll be updating this overtime with more pictures of the pieces as I start mocking them up on the s14.
Fitelite240!! is offline   Reply With Quote
Old 02-04-2021, 11:37 AM   #2
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Good info here, wish I could find more pictures of the b-pillar braces in an S15. Like how is the seat belts mounted in that chassis? Wanted to try to attempt to get those installed in my S14.
The front ladder brace would be a good find. The frame rails look similar, wonder if it's as simple as popping in some rivnuts and bolting that thing up.
Old 02-04-2021, 02:14 PM   #3
Fitelite240!!
As far as the ladder bar, From what I could see. - I haven't worked on my car in a little since starting my business. But, I was going to cut the metal out of the frame. Get a solid small cube of steel and weld it in, drill a hole in the cube big enough for the bolt to go through. Helicoil it and locktite on the threads when I install the bar fully.
For the B-pillars eh, Im thinking of just making my own. same thing with the C-pillars
Old 03-08-2021, 03:45 PM   #4
dru721
dru721 is an unknown quantity at this point
Spec-R - Roof Brace
Spec-R - Roof brace
for B pillar brace you can fit them and still have rear seats in.
dru721 is offline   Reply With Quote
Old 03-08-2021, 03:49 PM   #5
Fitelite240!!
Really? I haven't tried to mock them up since I started this. But, if you have some photos as reference and how, that would be dope. Lol I just may try to do it if it'll work.
Old 03-08-2021, 04:33 PM   #6
dru721
just pm your phone number hassale to load pics up from phone or you can check out my ig mrnismos14
Old 03-08-2021, 04:43 PM   #7
Fitelite240!!
Oh dude! I talked to you on instagram! Your in FTL lmao. I remember you saying you got them to fit, never got your pics though. I'll DM you my number.
Old 03-08-2021, 04:47 PM   #8
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Got detailed pics? Only one potato photo on your Instagram, about the only thing I could tell was that you had to cut a bit of the interior panel.
Old 03-08-2021, 05:24 PM   #9
Fitelite240!!
He sent them to me. I'm going to mock it up and get some detailed pics on here. Give me about a week and I'll update it.
Old 03-08-2021, 05:26 PM   #10
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Nice. Mine is in the body shop but I picked up a bunch of these. Will be referencing this thread when I get the car back.
Old 09-18-2022, 03:50 PM   #11
LoSt180
LoSt180's Avatar
Trader Rating: (18)
I got the front ladder brace installed in my s14 today.
Had to ditch a heat shield by the downpipe. Installed M10 rivnuts to the rails to hold everything in place. I put a washer between the brace and the body on the left, front most bolt. This is because the S15 has some extra stamping fit this bolt (can be seen in the S15 pics in the first post). For the holes, I found a step bit to be the easiest way. Don't forget to paint the drilled areas to minimize rust in the future.
Gallery of pics: https://imgur.com/a/4vEMSYX
Old 01-21-2023, 10:43 PM   #12
Musky014
Musky014 is an unknown quantity at this point
How did you find the front ladder bar? Did it make a noticeable difference?
Musky014 is offline   Reply With Quote
Old 01-22-2023, 11:20 AM   #13
jr_ss
This an interesting thread…
I’ve considered fabricating an entire chassis brace that is bolted to the underside in various locations, similar to the UR braces. The main reason I’ve considered it is so that I can put a belly pan on the entire underside of the car.
Old 01-22-2023, 01:07 PM   #14
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Found someone selling a set of all S15 braces a few years ago that came with the front ladder bar. Much to my surprise, out of all the braces I've installed, that ladder bar was the one that I noticed immediately.
Feel like it's a missed potential for the aftermarket to duplicate this part.
Old 01-22-2023, 01:49 PM   #15
jr_ss
While this isn?t an exact replacement, it does tie the tunnel into the frame rails at the front. One could speculate that adding an additional bar that ties to the front frame rails in a similar position to the bar you?ve installed would take it further.
https://ultraracing-usa.com/product/...s14-1995-1998/
Old 01-22-2023, 03:34 PM   #16
Musky014
I might have to try and source one now. Hopefully it fits past my exhaust
Old 01-22-2023, 04:12 PM   #17
LoSt180
LoSt180's Avatar
Trader Rating: (18)
It has plenty of clearance for a KA/SR setup, other engines may have issues depending on how it's routed.
If used turns up nothing, you might still be able to buy the brackets new. Looking on Nengun, here's part numbers. They don't say discontinued, but someone would have to place an order to find out...
Front Crossbar Assembly - 544B2-85F00
Rear Crossbar (subframe brace) - 554B2-85F03 (or 554B2-91F00)
Trunk Triangle brackets:
Rear Floor Stay Lh - 74845-85F00
Rear Floor Stay Rh - 74844-85F00
Trunk Bar Assembly - 79174-85F00
B-pillar brackets:
Floor Gasset Rh - 748B0-85F00
Floor Gasset Lh - 748B1-85F00
Old 01-22-2023, 04:54 PM   #18
Musky014
B-pillar brackets:
I'm more worried about my custom 3.5" dump pipe and screamer pipe getting in the way. Thanks for the part no. I'll look into it. I really feel like the front ladder brace will be beneficial
Old 03-02-2023, 05:33 AM   #19
Musky014
Update If anyone is still interested. I have now installed the rear subframe brace and the front ladder brace, both at different times. I started with the rear subframe brace and noticed an immediate difference with greater turn in response. I then installed the front ladder brace and notice further improvement to rigidity and turn in response. All in all both are highly noticeable and I wish I installed them sooner on in my ownership.
Old 01-13-2024, 03:36 PM   #20
Musky014
Just picked the spec r boot brace and triangles. Would Riv nuts be fine to fix it to the boot floor or is there a plate/thicker floor in the boot of the s15 to allow for the point fixing of the boot brace and triangles?
Old 01-14-2024, 09:47 AM   #21
inopsey
just to confirm, these 2 braces were 100% bolt in using factory munting areas and hardware?
which braces do have you installed and which ones made the most noticable difference, (besides these 2) ?
Old 01-14-2024, 04:44 PM   #22
LoSt180
LoSt180's Avatar
Trader Rating: (18)
I picked up the factory panels that are spot welded to the floor and will use rivnuts on the back wall. I've seen others get away with just rivnuts. It'll be my winter project at some point. Only issue is the tank is right there, so need to be careful with the drill or drop the tank.
Old 01-14-2024, 04:47 PM   #23
LoSt180
LoSt180's Avatar
Trader Rating: (18)
The front ladder brace needs rivnuts installed in order to mount. The subframe just replaces the cup washers and goes right on with no mods. The ladder brace was immediately noticeable, and was a big surprise to me.
