Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 04-09-2020, 12:32 PM   #1
mav1178
mav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfection
ORC clutch kit - in stock special
Light Series single clutch:
Metal Series twin clutch:
Vehicle specific clutch kits will vary only with the input shaft splines, flywheel mounting bolt pattern, and flywheel teeth pattern. Otherwise, what you see is (mostly) what you'll get.
These clutch kits are all currently in stock and ready to ship.
Prices below are shipped in CONTUS. 7.75% sales tax applies if you are in CA.
S13/14 SR20DET 5-speed manual (or any SR20DET swapped car)
  • Light Series 400 single plate (rated for ~290lb-ft crank torque) - ORC-400L-NS0207 - $975
  • Light Series 400 High Pressure single plate (rated for ~360lb-ft crank torque) - ORC-400L-HP-NS0207 - $1000
  • Metal Series 559 twin plate (rated for ~465lb-ft crank torque) - ORC-559D-02N - $1500
Z33 VQ35DE (or any VQ35DE swapped car)
  • Light Series 400 single plate (rated for ~290lb-ft crank torque) - ORC-400L-NS0613 - $1025
  • Light Series 400 HP single plate (rated for ~360lb-ft crank torque) - ORC-400L-HP-NS0613 - $1050
If you are interested, send me a PM or email [email protected]
Thanks.
Alex
mav1178 is offline   Reply With Quote
Old 04-12-2020, 08:45 AM   #2
jr_ss
Including power limits would help for a lot of people. There is a lot of mixed information was to what level each clutch can hold or is rated to.
Old 04-12-2020, 11:38 AM   #3
mav1178
Thanks, I added torque ratings for the parts.
Old 04-13-2020, 10:40 AM   #4
jr_ss
Good man. I know having that information has helped me in the past for purchasing clutches.
Now, does ORC make a 659 series for the SR? My current setup makes 39X ft/lbs of trq. When I up the boost and switch to E85, I would imagine I?ll be in the mid 400?s if I?m over 600whp.
Old 04-13-2020, 11:20 AM   #5
mav1178
https://www.orc-ntp.com/metal
Yes, they have a 659 and 659D for SR, rated for about ~540lb-ft crank torque.
If you're interested I can order for you in the future, PM for pricing. Japan is eager to sell so I can probably negotiate a lower price.
Alex
Old 04-28-2020, 10:51 AM   #6
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
whats the high torque rating does ORC have for the SR?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-28-2020, 02:32 PM   #7
SlmdCpe
SlmdCpe's Avatar
SlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enough
How much for just the clutch discs?
I have the metal series and Im looking to get an idea on how much replacement disc's will be.
SlmdCpe is offline   Reply With Quote
Old 04-28-2020, 05:58 PM   #8
mav1178
I'm assuming you meant highest:
Pro Carbon twin - 630 N-m ~ 465 lb-ft
Metal Twin 659 - 735 N-m ~ 542 lb-ft
PM me the model + serial number from the clutch kit.
I will need this info to ask Japan, they won't give me any price for replacement parts without knowing where the kit was originally purchased from.
Alex
