Old 01-14-2020, 10:02 AM   #1
bpat
bpat's Avatar
bpat is an unknown quantity at this point
1995 240sx - 2jz Singe Turbo
Hi,
I am selling my 1995 2JZ swapped S14.
Backstory:
I bought this car in high school with the stock KA24 probably back in 2011. I then acquired a 2JZ motor and R154 trans to swap in. This was a slow project that went on for most of my college days when I could find some extra money laying around. This car was built to have a fun and reliable weekend cruiser, not to have 1k hp. It pulls hard and makes me smile every time I drive it.
Car currently is tuned to a comfortable 16psi making around 430hp.
Car is rust free and super clean underneath. Engine has less than 300 miles since rebuild. All fluids were just changed.
Price $20,000. Please do not shitpost on the price. If you are serious, make an offer.
Parts list:
Engine:
SuperTech TIVN valves
SuperTech GDE Bronze valve gudes
SuperTech VS-T6I valve seal
SuperTech SPR-1015 dual spring kit
ARP Head Stud kit
Head Gasket
Hone, reconditioned block
New timing belt
new valve covers
new cam seals
new front and main seals
new piston ring kit
new pilot bearing
new clutch slave cylinder
new oil pump
Clevite rod bearings
Clevite main bearings
Clevite thrust washers
Freed motor mounts
Hotside:
Precision 6262 .84 turbo
Turbosmart manual boost controller
Custom 3" exhaust from turbo back
T4 exhaust manifold
Exterior:
Custom front bashbar
Fortune auto coilovers
s14 brakes
5 lug
navan rear valances (not installed)
Interior:
Nardi wheel
Nismo shift knob
Fuel:
Radium Fuel rail kit
Deatschwerks 1000cc injectors
New fuel lines
450 Walbro e85 pump
new NGK plugs
Turbosmart BOV/wastegate 14psi
Fuel pressure regulator
EMS/Wiring/Electronics:
AEM V1
Wiring specialties wiring harness
Aem 3.5 bar map sensor kit
Speedhut oil temp, oil pressure, water temp, boost gauges
Transmission:
R154
Main assl. bolt
Excedy Twin Clutch
ARP flywheel bolts
Beech performance short shifter
Marlin shifter socket
hub release kit
Xcessive trans mount
OEM trans seals
Marlin Crawler digital speed sensor
Cooling:
2x SPAL 12" pusher fan
flex-a-lite adjustable fan control
Intercooler
New battery located in the trunk
Some useful information:
-I live in Southern California, but the car is location near Detroit, Michigan at my families house. I basically never drive the car and think it is a waste to sit in the garage for the majority of the year. I have also been considering shipping it out if needed.
-Cars wheels are still from before the project started, so may need some proper wheels/tires to really get the power on the ground.
-Once warmed up, the car seems to hunt while idling, guessing a newer EMS would solve this issue. Drives fine though and hasn't stalled out on me.
-If a little cosmetic effort is put into this car, it would look amazing.
I will upload more pictures from my phone once approved
Thanks
-Brendan
bpat is offline   Reply With Quote
Old 01-16-2020, 05:13 AM   #2
inferno s14
inferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-known
beasty looking car
inferno s14 is offline   Reply With Quote
Old 02-12-2020, 10:21 PM   #3
AarenNinja
AarenNinja's Avatar
AarenNinja is an unknown quantity at this point
How was your wiring process if you don't mind me asking?
Ng'aww~
AarenNinja is offline   Reply With Quote
Old 02-24-2020, 05:29 AM   #4
s_decaquatro87
s_decaquatro87 is an unknown quantity at this point
interested in this and would like to make a cash offer. contact me at 9493386743
s_decaquatro87 is offline   Reply With Quote
Old 03-08-2020, 10:50 AM   #5
bpat
bpat's Avatar
We used a full Wiring Specialities harness, I believe a couple plugs on the engine were damaged and needed to be replaced, but other than that it was plug n play.
Just sent a text
Old 10-06-2020, 08:45 PM   #6
bpat
bpat's Avatar
Bump it up
Old 10-22-2020, 10:37 AM   #7
sash357
sash357 is an unknown quantity at this point
New to the forum, don't think I can PM. Please reach out 480-703-4380
sash357 is offline   Reply With Quote
Old 10-25-2020, 09:01 PM   #8
NismoTrini
NismoTrini is an unknown quantity at this point
7542444035 hit me up.
NismoTrini is offline   Reply With Quote
Old 10-27-2020, 07:26 PM   #9
sash357
I’m ready to buy if you still got this. 480-703-4380
Old 03-15-2021, 02:24 PM   #10
A.Diaz
A.Diaz is an unknown quantity at this point
Still for sale?
A.Diaz is offline   Reply With Quote
