Old 10-31-2019, 03:06 PM   #1
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Intermittent high idle. Help!
Hello all. I have a s13 Sr20det swap in my datsun. I’ve had it tuned with a powerfc. I have an issue where the idle is about 1100-1200 rpm about 80% of the time. The other times, it’s good at the 900 I’ve set it at. I’ve checked for vacuum leaks and even sprayed the vacuum areas to see if any changes. Anything that y’all recommend for me to test? Besides that, the engine pulls strong and boosts to 16 psi without issue. Thanks in advanced
Pic for attention
lexus baby
5t341tH is offline   Reply With Quote
Old 10-31-2019, 08:07 PM   #2
S14rebuild
Probly iacv acting up/sticking.
Remove it and clean it, or delete it and tune with power fc with throttle plate cracked open
Old 11-02-2019, 04:39 PM   #3
5t341tH
5t341tH's Avatar
I thought when the iacv is bad it causes low idle?
lexus baby
Old 11-02-2019, 05:02 PM   #4
S14rebuild
It could be opening like idle jump for ac on or powersteering adjust
Old 11-11-2019, 08:10 PM   #5
5t341tH
5t341tH's Avatar
took my iacv valve off and checked it out. it was pretty clean but i cleaned it some more. still have a high idle. anything else to check?
lexus baby
Old 11-14-2019, 06:54 PM   #6
5t341tH
5t341tH's Avatar
So I redid the tps setting again. On the powerfc, my tps reads 0.41 but shows 0.46 when I do it with my multimeter. I get a max of 4v at wot and at closed it’s 0.46. I took apart my intake manifold to find any potential leaks and also redid all my intercooler piping. I don’t believe it’s a vacuum leak as those should lower my idle and not raise it. I played with the throttle body screw and set it at the minimum opening. What I do notice though is my ignition timing would be jumping around while my idle is high. It would go from 0-14 and jump all over the place. What could be causing this? Unplugging my z32 maf kills the engine and unplugging the tps does nothing too. Unplugging the iacv has no affect either
lexus baby
Old 11-15-2019, 11:47 AM   #7
carcrazee
carcrazee's Avatar
carcrazee is an unknown quantity at this point
ya know i think we have the same issue and ive yet to figure this out either..., every sensor on my sr was brand new oem except for the iacv... my car has been like this for almost 4 years now lol...runs just fine though
carcrazee is offline   Reply With Quote
