10-12-2018, 10:16 AM | #1 |
1989 Nissan 240sx S13 Silvia LS1 Drift Car
https://sandiego.craigslist.org/nsd/...716841033.html Runs great! Sounds amazing! 425hp https://vimeo.com/album/5465304 Car comes with one free day of instruction from professional drifter Matt Powers. http://www.powersdrives.com Not street legal in CA but can be converted if desired. The original build of the car was featured in Super Street Magazine. http://www.superstreetonline.com/fea...san-240sx-s13/ Original copy of the magazine comes with the car, although it's in pretty bad shape. Car was professionally built at Togue Factory in Chicago. -LQ9 6.0 iron block with 37k miles* -Comp Thumper Torque Cam -Ported throttle body -Walbro 255 fuel pump -Champion radiator -Stage 3 T56, less than 2500 miles. SSR 32 spline mainshaft, CTSV gearing, pads, forks, keys, etc. Will handle 1000rwtq -Stage 2 competition clutch -Competition 12lb flywheel -Hurst short throw shifter -Welded R200 diff with 4.09 FD -300zx turbo brakes, 4 calipers in rear -Nameless hydro E-brake -Holly engine mounts -New subframe with welding bracing for extra support -Stance GR coilovers -Stance upper/lower control arms -New tie rods, ball joints, and bearings -Cusco front strut bar -Nagisa front fender braces -Aluminum subframe bushings -Tube front -Sparco steering wheel -Sparco racing seat - drivers side only -Stock passenger seat -4 point seatbelt harnesses -Version Select sideskirts/bumper -Enkei RPF1's, 9.5in front, 10.5in rear (rough) with new tires -Set of 4 extra wheels blue (rough) with new tires -Trunk mounted fuel cell -Trunk mounted battery -Villains angle kit (not installed) Speedo does not work Also available: 2018 Innovative Car Trailer 83" x 16' Douglas Fir wood deck, triple reinforced tongue, one-piece wiring harness, under-chassis 5' ramps with storage, 3500# axles with EZ-lube hubs, electric brakes on rear axle, boxed sealed LED taillights, 15" radial tires, mounted spare, LED running lights. $2500 I'll make you a sweet deal if you buy both. |
