10-04-2018, 08:04 PM | #1 |
WTB S14 LS Swap Parts I NEED ALOT OF STUFF
Doing an LS Swap, WTB a ton of stuff:
I will be updating this thread as I go when I obtain parts. If it's on this list, I NEED IT! I currently have a Z32 transmission, so I can go with that Z32 TRANNY SWAP PARTS LOJ LS to Z32 240SX Swap Kit LOJ Z32 Driveshaft Z32 300ZX Starter ISR HGC Swap Headers (or equivalent) Wiring Specialties Harness ALTERNATIVELY, IF YOU HAVE PARTS FOR A T56 TRANSMISSION, I MAY WANT THE FOLLOWING FOR THE SWAP PARTS IF I GO T56: T56 TRANNY SWAP PARTS ISR LS Swap Mounts (or equivalent) ISR LS Swap Y-Pipe (or equivalent) ISR T56 Master Cyl (or equivalent) ISR Steel Driveshaft (or equivalent) Canton Racing Oil Pan (or equivalent) GTO Oil Pickup Canton Oil Filter Relocation (or equivalent) I ALSO NEED ENGINE PARTS ENGINE BUILD PARTS LS2 Intake Manifold Cable-Driven Throttle Body CTS-V Alternator CTS-V Alternator Bracket CTS-V Water Pump CTS-V Power Steering Pump CTS-V Power Steering Pump Bracket CTS-V Harmonic Balancer CTS-V Idler Pulley CTS-V Main Accessory Belt HP Tuners MPVI2 AFM Delete Kit VVT Delete Kit LS3 Camshaft LS6 Valve Springs Trunnion Kit LS2 Timing Chain Kit LS Lifter and Guide Kit 0.080 Wall Pushrods Timing Chain Dampener Deatsch 60lb Fuel injectors 4-Corner Steam Kit More than likely I'll be going 5.3L engine, but if I get a deal I get a deal, nomsayin |
10-04-2018, 09:00 PM | #2 |
in other words, you need an entire swap.
posted in the wrong section I have an ls3 stock cam out of a motor that had 13k miles on it make me an offer if your interested |
10-04-2018, 09:11 PM | #3 |
10-10-2018, 02:00 PM | #5 |
