Old 07-05-2018, 10:15 AM   #1
hellyeah
hellyeah is an unknown quantity at this point
S14 newbie questions
Hi guys
About a week ago I became a proud(?) owner of a reasonably modded 2000 S14 kouki.
Have a couple of quite newbie questions:
1)There is some weird thing happening to the clutch pedal. When I just bought the car, the pedal was so stiff that my left leg was hurting next couple of days. Now it's halfway very soft and doing nothing (like wiggling) and then it's again stiff. The liquid level is ok. Can it be slave cylinder?
2)When I am already in some gear and pressing accelerator pedal just a little bit, I hear a clunk in the rear end. Is it differential? Driveshaft?
Thanks in advance!
hellyeah is offline   Reply With Quote
Old 07-05-2018, 10:47 AM   #2
flartius
flartius's Avatar
flartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud of
Kouki is from 97 to 98... just sayin.
¯\_(ツ)_/¯
flartius is offline   Reply With Quote
Old 07-05-2018, 10:53 AM   #3
hellyeah
Its JDM with SR20DET which was imported to UK and in 2011 arrived to Cyprus
Old 07-05-2018, 01:42 PM   #4
firejackal
firejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enough
1) Sometimes there can be air in the clutch fluid, and then also a leaky master or slave cylinder can do that. I've had a slave cylinder leak air through the plunger that made the pedal hard sometimes, soft other times.
2) probably it's a bushing in the driveshaft or differential.
Sent from my ONEPLUS A6003 using Tapatalk
Join my discord server! https://discord.gg/SDN7fw2
firejackal is offline   Reply With Quote
