Old 09-20-2017, 05:09 PM   #1
Tuffyswanson
Tuffyswanson is an unknown quantity at this point
s13 1990 Nissan 240sx hatch
Up for sale is my 1990 240sx.
Sold!!!
I bought this car in December of 2012 from Palm Spring Toyota Dealership in Florida. The car had one previous own, a lady who bought it right off of the showroom floor. Clean title and 153600 miles on the chassis. Car now has 159,870 miles.
Needless to say the car had very little rust being a FL car, which is why I bought it. I had planned to autocross and maybe a little drift/drag with the car but i never got around to doing any of that- just building it and driving it on the weekends. Overall the car was in good shape but it did have a little bit of a repair job on the driver side rear quarter panel, which i have since re-repaired (mostly). I also replaced the passenger door because the original one had some rust under the side view mirror and i couldn't weld at the time.
The car was completely stock.
Since that time, I have slowly modded the car to where it currently is. I have tuned the car myself with the help of a local tuner and it is probably running around 280-300 whp at a very conservative tune and 16 psi. Most of its time with me it was running on the stock T25 until late last year when i upgraded to a T3 setup. The car, with a complete tune, can do upwards of 400 whp with the current turbo. The car is in good shape, pulls hard, and handles pretty good. I also painted the car myself, which came out just okay- primer, color, and clear was applied.
Parts list:
SR20Det S13 Blacktop Motorset 2,100.00
Adaptronic 440 select S13 SR ECU 1,260.00
BC Racing Coilovers 979.00
SR20det water pump and belts 80.00
Wilwood non assisted BMC 220.00
Circuit sports slotted/drilled Rear Rotors 130.00
Hawk brake pads Rear 75.00
AGP front steel braided brake line 60.00
AGP Rear steel braided brake line 55.00
Circuit sports Sr20det Alternator 210.00
Circuit sports Clutch pivot arm 25.00
Nissan OEM SR20det Throw out Bearing 45.00
Exedy Clutch master cylinder 20.00
Exedy slave cylinder 15.00
Tial 38 mm wastegate, 0.7 bar 280.00
P2M aluminum coolant overflow tank 86.00
OEM Nissan T3 turbo inlet gasket 18.00
P2M -250cc mini oil catch can tank V2 41.00
P2M power steering resivoir 113.00
Isis FMIC M-spec 200.00
Isis FMIC piping kit 180.00
Isis SR20det Hotpipe w/BOV flange 40.00
Isis Aluminum radiator 180.00
Isis silicone radiator hose kit 40.00
isis Fan shroud kit 110.00
isis High pressure Power steering line 85.00
Custom fab topmount down pipe with v-band 300.00
isis SS Downpipe 75.00
Isis GT single exhaust 220.00
Spec stage 3 Clutch kit 300.00
Spec Aluminum Flywheel 410.00
Gates 19619 Heater Hose 25.00
Gates 19628 Heater Hose 20.00
Megan Racing Engine and Transmission Mount kit 180.00
Isis SS Test Pipe 43.00
Isis Aluminum Intake Pipe 40.00
Isis Silicone Hose 2.5-2.75 Reducer Black 10.00
Isis Silicone Hose 2.75"-3.00" Reducer Black 10.00
Isis MAF Adapter Nissan Z32 16.00
Isis 3" Cone Air Filter 20.00
Circuit sports Oil Filter relocation Kit 105.00
Tial Q Blow Off Valve 6psi spring 260.00
Tomei T-Trax Hypoid gear Oil GL-5 80W-90 44.00
Greddy Oil Filter S14 Sr20 15.00
Kaaz 2-Way differential 650.00
Isis T3/T4 Universal Turbo Blanket 65.00
OEM SR20det Injector O-rings 15.00
Tanabe VLS oil pressure gage 180
Aluminum Agency Power Shift knob red 40.00
Coverlay Dash Cover Black 240sx 136.00
E-Brake drift Knob-Red 12.00
XXR 527 17x8.25 E+35 440.00
Federal SS-595 Drift tires 360.00
Nissan Rubber (under shift boot) boot 15.00
Nissan OEM Rear Main Seal 30.00
Front mount intercooler pipe and silicone couplers 100.00
Redline MT90 transmission fluid 75W90 GL4 45.00
Doc Race topmount T3 manifold w. wastegate 560.00
Nismo 740cc injectors 545.00
Precision 3231E Turbo 400.00 (killer deal from a guy on zilvia)
Half Shaft 5-bolt for new diff 150.00
Fuel Pressure regulator 90.00
Duralast Platinum Battery 150.00
Battery Relocation kit 100.00
Durale Electric Fan controller 70.00
AEM UEGO AFR gage 220.00
Tanabe OLED Water Temp gage 150.00
Tanabe VLS OLED Oil Pressure gage 180.00
Autometer Pro-Spek Boost gage 230.00
NRG hub and quick release V2.5 190.00
NRG deep corn steering wheel 130.00
New OEM color paint 300.00
Used good condition IACV 85.00
Top end gasket set 100.00 (included with sale)
No trades unless r32 GTR
Sold!!!!!
Text Andrew at 860-214-five030 for more information
Tuffyswanson is offline   Reply With Quote
Old 09-21-2017, 04:17 PM   #2
ReallyWantsA240SX
ReallyWantsA240SX is an unknown quantity at this point
Modifications don't add value to your car.
GLWS either way!
ReallyWantsA240SX is offline   Reply With Quote
Old 09-21-2017, 04:56 PM   #3
Tuffyswanson
Reallywants, thanks for the enlightening bump, I'll take that into consideration champ.
Old 09-21-2017, 09:39 PM   #4
SlammedCarsUSA
SlammedCarsUSA's Avatar
SlammedCarsUSA is an unknown quantity at this point
Don't listen to this guy ReallyWants, This car with the complete swap is truly only worth the book value, like every other 240 that sells for the exact book value!
Instagram: SlammedCarsUSA
SlammedCarsUSA is offline   Reply With Quote
Old 09-22-2017, 09:00 AM   #5
FMFsx
FMFsx is an unknown quantity at this point
That's golden
FMFsx is offline   Reply With Quote
Old 09-22-2017, 03:24 PM   #6
bavarian666
bavarian666 is an unknown quantity at this point
Testfully moded clean car GLWS
"Did you ever saw hater doing better then you"
bavarian666 is offline   Reply With Quote
Old 09-22-2017, 04:29 PM   #7
Tuffyswanson
Thanks for the good words guys!
Old 09-23-2017, 01:36 AM   #8
TheRealSy90
TheRealSy90's Avatar
Just part it out if you're trying to get that much out of it. Selling it all together just isn't going to net you 9 grand.
Such a good signature.
Old 09-23-2017, 03:23 PM   #9
Tuffyswanson
Thanks for your input and the bump Real
Old 09-24-2017, 06:23 AM   #10
Tuffyswanson
Price drop, $8700 OBO
Old 09-24-2017, 06:59 AM   #11
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
I see where you factored in the prices of the parts, but what about your labor to install them? Your mechanical talent, your painting skill, your tuning acumen? Clearly, you should start this car at more like 18k, having had your special touch all over it...
mechanicalmoron is offline   Reply With Quote
Old 10-02-2017, 06:01 AM   #12
Tuffyswanson
Price drop, $8500 guys
Old 10-13-2017, 01:45 PM   #13
Tuffyswanson
Price drop, $8200.
Old 10-25-2017, 05:46 AM   #14
Tuffyswanson
Car sold, mods, please lock up
240sx, drift, hatch, nissan
