Old 07-09-2017, 10:09 PM   #1
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Talking Fuel pump priming issue
The problem is that the fuel pump will prime but it will not cut off like normal.
when turned to ACC the fuel pump activates priming the fuel system (normal) but the abnormal part is that it doesn't cut off (normally after 5 sec. the fuel pump should deactivate)
what causes the fuel pump to cut off? deactivation of the relay?
S-Nation S13 is offline   Reply With Quote
Old 07-10-2017, 08:18 PM   #2
Kingtal0n
Kingtal0n's Avatar
Ecu -> relay -> fuel pump
Sometimes people re-wire it to get power from somewhere else. That would keep it on all the time when the key is turned.
The ECU is supposed to turn it on / off though, this is the normal way. Some ECU throw ground to the relay (Sr20det) and some throw 12V (LSx ecu) so it depends what computer you use.
Old 07-10-2017, 08:44 PM   #3
S-Nation S13
Trader Rating: (92)
I was using a stock 62 ecu now in using a power FC but I'm still having the same issue. On ACC fuel pump turns on stays on until I turn to OFF. Which leads me to believe my fuel pump + signal is wired on ACC circuit.
fuel pump, relay
