Old 02-11-2017, 09:18 PM   #1
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
s14 Crank Angle Sensor Confusion
Hello everyone,
I have an s13 transmission on my s14. There is no place for me to put a crank position sensor on the bellhousing. I know that this sensor is not needed for engine operation and am trying to get rid of the trouble code. How do I bypass the sensor? Can I use a resistor? Also, I deleted my egr and want to get rid of that code too. Can I use a resistor for that?
Thanks,
Evan
apex128 is offline   Reply With Quote
Old 02-16-2017, 08:05 AM   #2
apex128
Bump. I need help on this guys.
Old 02-16-2017, 08:52 AM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
Measure, drill and tap hole to make it work on the bell housing. but that's me and i would of done it when i have the tranny out.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 02-16-2017, 11:07 AM   #4
apex128
I would have done it when the tranny was out too. The issue is that I bought the car swapped. I just want to make sure there is no other way before I go about pulling the motor out / dropping the transmission. Do you know if the signal from the sensor is constant or does it vary with rpm? Also do you think that this code would fail emissions?
Old 05-07-2017, 05:56 PM   #5
apex128
Bump. What ohm resistor could i use to bypass this thing?
Old 05-07-2017, 11:36 PM   #6
Agamemnon
Agamemnon's Avatar
You don't. Pull the trans out and follow this guide and do it right.
http://forums.nicoclub.com/s13-ka24d...p-t384931.html
cel, crank position sensor, ecu, egr, trouble code
