Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 07-07-2016, 10:26 AM   #1
Enjuku Racing
Trader Rating: (29)
Enjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to behold
Feedback Score: 29 reviews
Send a message via AIM to Enjuku Racing
Enjuku Racing - ISR Auto to Manual Conversion Clutch Line - Nissan 240sx S13/S14/S15
ISR (Formerly ISIS) Performance Auto To Manual Conversion Clutch Line - Nissan 240sx 89-98
ISIS [I-sis] Performance Steel braided clutch line with CNC machined fittings. Clutch lines are 52" in length. For converting your 240sx from automatic to manual transmission.
The ISIS Performance clutch line utilizes a seperate fitting from the line so you don't need to keep twisting the line to install it, you just install the fitting and then the line. This is a much better deisgn than some of the other lines out there.
ISIS Performance clutch lines are made of the finest PTFE hose and permanently crimped-on zinc plated steel fittings. Our hose is made with an extruded PTFE core and a stainless steel wire braided cover. They reduce volumetric expansion giving you the reliability and safety you demand.
Overtime and under continuous use OEM rubber lines can swell and expand causing failure. The rubber cover is also vulnerable to attacks from the ozone layer rubber which causes it to deteriorate. In extreme applications (Auto X, racing, hard driving) rubber hoses might be susceptible to flying debris. Stainless steel lines will give protection from theses issues along with enhancing the appearance of your installation.
For added protection against abrasion and corrosion this line utilizes a Yellow PVC outer cover.
Please note you do not need the smaller clutch line with this setup. This runs from Master Cylinder all the way to Slave.
In Stock and Ready to Ship!
$35.99
Office: 352-241-8399 / 1-888-SR20DET (772-0338)
YouTube.com/c/EnjukuRacingParts
http://www.enjukuracing.com
[email protected]
Enjuku Racing is offline   Reply With Quote
Old 07-07-2016, 01:11 PM   #2
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
these are also great for already manual tranny cars looking to get rid of the annoying hard line + braided slave line setup! using one of these makes life SO much easier when having to remove the line to the slave cylinder! Or just removing the slave cylinder if swapping your clutch/tranny.
