Old 06-29-2016, 04:20 PM   #1
Karkarbink
Karkarbink is an unknown quantity at this point
SR 1993 SR20DET 240SX S13 $6,500 Spearfish, SD
Car is SOLD! A nice couple from New Jersey came down and picked it up! Thanks Zilvia!
Hello,
First I'd like to thank you for checking out my car. I want to take this time to explain the in's and out's of this car; the good and bad. I am going to tell every little detail about this car that any owner would want to know. This car was meant to be my daily/drifter, but it can go any way really.
Asking Price: $6,500 Firm
ITEM: 1993 Nissan 240SX
TITLE: Clean
Motor: SR20DET Redtop
Tune: RS Enthalpy @ 375-390HP - I've never had it dyno'd, but the tune is for just under 400HP.
2871R .64 A/R GT-RS style W/ HKS wastegate
Taka water/oil lines
Hybrid Dynamics turbo adaptors
Megan Racing Turbo Outlet
Cat delete pipe
Filled motor and tranny mounts
Blitz DP
5zigen Rocket Exhaust
Greddy RAS
Brian Crower Stage II Cams
Brian Crower Valve Springs and Ti Retainers
Greddy FMIC
HKS BOV
Enjuku Hotpipe
Deatchwerks 550CC injectors (Less than one year old)
Circuit Sports Fuel Rail
Z32 MAF
S15 water pump
Greddy oil pan
S14 blacktop oil pickup
Koyo Radiator
FAL dual puller fans
Apexi S-AFC II
Freddy Intake Manifold
RS-Enthalpy ECU Tune
Walboro 255 fuel pump
Nismo Radiator Cap
SAMCO radiator in/out hoses
Chase Bays Tucked Harness
Engine bay is tubbed, stitch-welded, and painted gold.
Fuse box relocated to glove box
Battery relocated to trunk
Aeromotive Fuel Pressure Regulator
Comments:
I really think this motor is solid. The bottom end has never been tampered with, but the top end has had some work done (listed above). This motor has been extremely reliable. When I bought it (in a different shell) I drove it around for months without any problems, no leaks, no inter cooler piping blowing off, nothing. Since then, the motor has been swapped into a newer and pristine chassis. The swap into the new chassis included a new Chase Bays harness, new Deatschwerks injectors, new Spec Stage 5 clutch/pressure plate, new clutch slave and master cylinder, and some other minuscule things. I did have a boost leak, but I have taken care of it. The motor is running Royal Purple.
Transmission:
Spec Stage 5 Clutch (Less than 100 miles)
Spec Pressure Plate (Less than 100 miles)
New OEM Master Cylinder
New OEM Slave Cylinder
New Clutch Line
Kaaz Advance 2-way Differential
Comments:
Just replaced the clutch and transmission 04/30/2016. We also replaced the throw-out and pilot bushing. The transmission is running Royal Purple. Clutch will need some fine adjusting. Clutch has less than 100 miles on it.
Suspension/Brakes:
Z32 Brakes with drilled and slotted rotors (front)
Tucked brake lines
MR street coilovers
Pilot STB’s F&R
Ichiba 5-lug hubs
Extended LCA's
Shortened Knuckles
P2M Rack Spacers
Comments:
The suspension still rides great. Surface rust on the coils, but that's inevitable. Rotors are brand new with less than 500 miles. Z32 Calipers painted gold.
Exterior: White
AIT Aggresive Aero
AIT Rear 30mm Overfenders
D-Max Daimyo hood
Origin Roof Wing
Origin Trunk Spoiler
Varrstoen (knock-offs) ES2 18'' 5x114.3 18x10.5+22 18x9.5.+22 (White)
Brand New Nankang tires 235/40/18 (Rear)
Nitto NT05 30% left (Front)
Brand New windshield (will be professionally installed)
Comments:
The body was repainted white in 2014. The front bumper is cracked, but not too bad (only noticeable from close). The front driver-side fender has a little nick near the top. The rear bumper has a finger-sized crack on the passenger side. The hood has a scratch close to the wipers from transport after painting and one right by the left hood pin. The wheels are color-matched with the paint, but could use repainted because of curb rash or wear from mounting/dismounting. I may re-paint the wheels if sale takes too long.
The chassis is straight and hasn't been molested. I believe it was garage kept for at least part of it's life, so there is no/minimal rust.
The bay is tubbed, stitch-welded, and painted gold. The guy that did it put quite a bit of time into it. There is one spot on top of the driver side frame rail where brake fluid ran and ruined a small section of paint, 3x5". It's only noticeable if you're working underneath the intake manifold.
Interior:
Sparco 340mm Wheel (not mounted yet)
Corbeau Forza I seat driver
Corbeau IDK seat passenger
AEM Tru-boost Guage
AEM Water Temp Guage
AEM Oil Pressure Guage
AEM Wideband
Center Mount Guage Pod
Pillar Guage Pod
Greddy spin knob
Comments:
This is where YOU'D have to decide what you would want to do, drifter or daily? I have 80% of all the interior pieces and the car will come with them in there. The dash has a crack on driver side, but the passenger half looks pristine. Could use new carpet if you want a super clean daily. All the guages work on the cluster except fuel. The float arm in the tank is broken. Might fix this weekend. I have taken out heat and A/C controls and placed a custom stainless steel bezel with a cutoff switch and S-AFC II display. There is also a button missing from the cluster that will be replaced. Power windows work great. Also, there is no rear seat. I could possibly get one from a friend.
Extra's:
Two 17" Mustang wheels painted white (drift spares)
S13 Dash
Hundreds of bolts and stuff
Turbo outlet gaskets/exhaust gaskets
Front camber plates
All the spacers you'd ever need for proper fitment
HKS Turbo Timer
UPDATE July 3rd: Went out for a cruise today and noticed car is running a little rich in boost. I will do more investigating; I think it may be the SAFC or possible boost leak. Should be fixed this week, I will keep everyone updated. Also, video is up with pictures coming soon.
UPDATE July 20th: New windshield is in and car is running great in boost! Problem solved.
Thanks,
Kar
Karkarbink is offline   Reply With Quote
Old 06-29-2016, 06:49 PM   #2
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
Great write up and nice car.
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 06-29-2016, 11:01 PM   #3
Z32TwinTurbo
Z32TwinTurbo can only hope to improve
very good deal
Z32TwinTurbo is offline   Reply With Quote
Old 06-29-2016, 11:01 PM   #4
sr20time
sr20time is an unknown quantity at this point
great deal
sr20time is offline   Reply With Quote
Old 06-30-2016, 06:45 AM   #5
RodRodRacing
RodRodRacing is an unknown quantity at this point
very nice description and a really good car. Good Luck with the sale!
RodRodRacing is offline   Reply With Quote
Old 06-30-2016, 04:28 PM   #6
Karkarbink
Thank you all, I appreciate it!
Old 06-30-2016, 06:25 PM   #7
TheRealSy90
TheRealSy90's Avatar
Why have the safc if you have the enthalpy tune? I did the same thing, even had the safc zeroed out so that it wasn't really doing anything. When I finally removed it it ran way better XD
Such a good signature.
Old 06-30-2016, 07:35 PM   #8
subiesean
subiesean's Avatar
Do you have more photos of the car you could post?
Ho.Mo.Co.
Old 06-30-2016, 08:31 PM   #9
HOMEMADE240SXTURBO
HOMEMADE240SXTURBO's Avatar
HOMEMADE240SXTURBO can only hope to improve
Lol I guess I'll just use my imagination.
-Moderation
HOMEMADE240SXTURBO is offline   Reply With Quote
Old 06-30-2016, 09:35 PM   #10
Karkarbink
Just use it for monitoring throttle position, knock, and airflow. I have it zero'd as well. The car runs great. 11.5afr wot and 14.75afr at idle. I'm impressed that a mail tune can be so precise
Old 06-30-2016, 09:38 PM   #11
Karkarbink
Yes, I am taking high-res photos this week. I'm planning on embedding the really good shots and having an album with all the other misc shots. I also have a video of it running/driving. All coming by Monday.
Old 07-01-2016, 08:36 AM   #12
MJenkins1101
MJenkins1101 is an unknown quantity at this point
I'm in for video and more pics.
MJenkins1101 is offline   Reply With Quote
Old 07-01-2016, 09:10 AM   #13
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Do you happen to have a build thread?
[email protected]
hanzbrady is offline   Reply With Quote
Old 07-01-2016, 10:00 AM   #14
Karkarbink
I don't, but I do have a lot of receipts.
Old 07-01-2016, 10:12 AM   #15
hanzbrady
hanzbrady's Avatar
It wasn't so much for purchase purposes I just wanted to see the build of a clean car haha. Anyways free bump!
[email protected]
Old 07-01-2016, 11:23 AM   #16
Peach
Peach's Avatar
Peach is an unknown quantity at this point
This build is absolutely immaculate. This is the first fairly priced s13 I've seen in a very, very long time. I'll be back in SoDak in a couple weeks for my wedding (I grew up there) and if it's still for sale then we will absolutely be in contact.
So, if anyone out there is reading this thread, buy this car before I sell mine.
Or else this shit is gone.
Peach is offline   Reply With Quote
Old 07-02-2016, 06:39 PM   #17
Karkarbink
Thanks, I appreciate it!
Old 07-03-2016, 08:52 PM   #18
Karkarbink
Video is live! Pictures coming soon!
Old 07-04-2016, 02:40 AM   #19
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
Trades? 10char
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 07-04-2016, 12:35 PM   #20
Karkarbink
Originally Posted by Reece View Post
Trades? 10char
Reece,
I would be open to trades for a newer Harley Sportster. I will also entertain other trades.
Thanks,
Kar
Old 07-04-2016, 04:25 PM   #21
RD_240
RD_240 is an unknown quantity at this point
Would love to have this.. a bit out of price range.. won't be able to afford the ticket there and gas to drive back.. haha.
GLWS
RD_240 is offline   Reply With Quote
Old 07-05-2016, 05:17 PM   #22
Rado
Rado's Avatar
Rado is an unknown quantity at this point
Clean build and good price! GLWS
Rado is offline   Reply With Quote
Old 07-22-2016, 11:22 AM   #23
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
Great Car, I'd love to pick this up.
teamsprock is offline   Reply With Quote
Old 07-22-2016, 08:53 PM   #24
dr_
dr_ is an unknown quantity at this point
are you willing to ship?
dr_ is offline   Reply With Quote
Old 07-24-2016, 11:26 AM   #25
Karkarbink
Car is sold!
Old 07-24-2016, 12:31 PM   #26
ben33327
ben33327's Avatar
ben33327 is making his/her stupidity well-knownben33327 is making his/her stupidity well-knownben33327 is making his/her stupidity well-knownben33327 is making his/her stupidity well-known
i can't believe it took that long!!!
ben33327 is offline   Reply With Quote
240sx, 5lug, s13, sr20det
