Old 06-19-2016, 07:49 PM   #1
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
Dean's vvti 1JZ/cd009 S13 Hatch daily drifter build thread
Sold the engine, keeping the car.
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
Old 06-24-2016, 05:46 PM   #2
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Can't wait to see it run! I'm in the middle of a 1j vvti swap as well
corkscrew is offline   Reply With Quote
Old 06-24-2016, 10:02 PM   #3
drifter92
drifter92's Avatar
sold the engine, keeping the car
Old 06-24-2016, 10:05 PM   #4
drifter92
drifter92's Avatar
Old 06-24-2016, 10:07 PM   #5
drifter92
drifter92's Avatar
Old 06-24-2016, 10:15 PM   #6
drifter92
drifter92's Avatar
Old 06-24-2016, 10:24 PM   #7
drifter92
drifter92's Avatar
intercooler piping fab and cutting throttle body to remove traction control and give me some room for my radiator hose. I also removed the large aluminum air tube from the OEM turbo inlet/outlet and blow off valve housing. I clocked the turbo inlet to give myself more room as well.
Old 06-24-2016, 10:26 PM   #8
drifter92
drifter92's Avatar
Old 06-24-2016, 10:28 PM   #9
drifter92
drifter92's Avatar
running power and ground wires to everything
gates barricade 3/8" fuel line
Old 06-24-2016, 10:32 PM   #10
drifter92
drifter92's Avatar
chopping the front of the car to allow more room for a clutch fan and ac condensor to both fit. moved the radiator roughly 2" forward following "AS240"s example from the 2JZ swapped s-chassis thread
Old 06-24-2016, 10:33 PM   #11
drifter92
drifter92's Avatar
brand new engine harness from Tweak'd Performance
THIS GUY IS AWESOME
BUY FROM HIM!
Old 06-26-2016, 11:52 AM   #12
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
Nice Build!
Learning a lot for my 1jz vvti build.
keep it up!
Freddy is offline   Reply With Quote
Old 06-26-2016, 12:27 PM   #13
corkscrew
corkscrew's Avatar
Dude you should make a jig or something to replicate your hot side piping. I bet a million people would buy pre made piping to replace the stock J pipe and other nonsense. I know I would lol.
Old 06-26-2016, 09:39 PM   #14
drifter92
drifter92's Avatar
Originally Posted by Freddy View Post
Nice Build!
keep it up!
Thank you! I appreciate it man, I like helping people figure out things that I've had to figure out.
Maybe, I used the OEM 1JZ compressor outlet bend combined with an OEM SR20 T25 compressor outlet bend piece to make that little twisty pipe, then the turbo air inlet is a simple 2.5" 45 degree intercooler pipe welded to the OEM flange clocked just right so that it clears the clutch fan, turbo coolant lines, and whatever electrical connector that is next to it on the engine.
Old 06-26-2016, 10:08 PM   #15
drifter92
drifter92's Avatar
Cleaned up the frame rails and removed the left overs from the radiator support.
This is where my radiator pegs stick through the OEM
power brace. I will clean these holes up later.
Power brace mounting, these tabs will be welded to the cross-tube, and have holes drilled for the radiator pegs to pass through.
also, I picked up this #swag hood this weekend
Old 06-27-2016, 07:07 AM   #16
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
nice work. this motor and trans combo is awesome.
Black240Ct is offline   Reply With Quote
Old 06-27-2016, 08:17 PM   #17
DayTex
DayTex's Avatar
DayTex is an unknown quantity at this point
Looking good, cant wait to see you rip it at the lonestar events!
DayTex is offline   Reply With Quote
Old 06-27-2016, 09:07 PM   #18
Mzag
Mzag is an unknown quantity at this point
Very nice build! Did you have any fitment issues with the future fab turbo elbow and the trans? Im currently doing the same setup and have seen where people need to cut and re route the elbow
Mzag is offline   Reply With Quote
Old 06-27-2016, 09:16 PM   #19
drifter92
drifter92's Avatar
I dont have any issues, im using a maverick motorsports adapter plate with a milled bellhousing. It clears without any issues.
Old 06-28-2016, 08:40 PM   #20
drifter92
drifter92's Avatar
Im going to get a smaller AC condenser so i can us the factory headlight motors in the OEM location... and I have to weld up my own AC lines anyway, so it will all work out well
Old 07-01-2016, 08:45 PM   #21
corkscrew
corkscrew's Avatar
More updates!
Old 07-01-2016, 08:50 PM   #22
drifter92
drifter92's Avatar
I havent made any progress on the front end work because Im waiting to get a smaller AC condenser. Im headed to the junkyard at 8AM tomorrow morning to find a condenser that will fit for me. Probably end up using a Honda Civic condenser and lines.
Old 07-01-2016, 11:49 PM   #23
TheRealSy90
TheRealSy90's Avatar
Love how you're keeping AC and clutch fan. Going to be an awesome car plus the cd009.
Such a good signature.
Old 07-03-2016, 01:38 AM   #24
drifter92
drifter92's Avatar
I went to the junkyard today and looked through a TON of AC cpndensers from all kinds of different vehicles and I didnt find anything that looks like it wil be easier to use than my OEM condenser because of width or hose orientation, orifice tubes, expansion chambers, etc. Im going to just remove the headlight motor and weld a bracket to my headlight housings that holds them up in the "ON" position so they will not retract.
In the morning, I'm going to begin welding up the front end parts and install the radiator, AC condenser, rad. hoses, engine harness, and intercooler; Then i'll work on getting my engine harness installed and maybe get it RUNNING TOMMOROW!?!??!?!
Old 07-03-2016, 11:37 PM   #25
drifter92
drifter92's Avatar
I ordered some more fuel line today to finish the fuel delivery system. Yay!
Also I welded up my front end parts, the lower radiator support is there now. I just need to add the caps to the front frame rails and weld the tow hook area which is torn apart on my car. My welding machine sucks so excuse the ugly welds... I really need something better.
Just waiting on $$$$$$$$$$$$$
Old 07-15-2016, 10:53 PM   #26
drifter92
drifter92's Avatar
Im working on the car still, picture coming soon. Not running yet
Old 07-16-2016, 06:41 AM   #27
corkscrew
corkscrew's Avatar
Excited to see the progress man
Old 07-17-2016, 07:47 PM   #28
drifter92
drifter92's Avatar
Power steering lines DONE
fuel lines DONE
radiator hoses DONE
heater hoses DONE
Engine Harness DONE
Power and grounds DONE
The engine turns over with the key but I'm not getting spark, im trying to figure out why right now.
Old 07-22-2016, 09:54 PM   #29
drifter92
drifter92's Avatar
IT RUNS!!!!!!!!!!!!!!!!!
https://www.youtube.com/watch?v=xZFpY02xMh8
Old 07-23-2016, 05:13 AM   #30
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Legit guy...
