06-06-2016, 01:25 PM | #1 |
Nismo 2 way LSD play normal?
So on my Nismo 2 way I can grab one of the half shafts and rotate it about 1/8 to a 1/4 inch and the other half shaft will rotate the same distance in the opposite direction and the diff makes a slight clunk. Is this normal for 2 ways? I have a bad clunk coming from somewhere in the rear end at low speeds when turning and I'm trying to pinpoint it.
Here's the video for reference. Thanks everybody! https://youtu.be/LMbHUmePV7w |
06-06-2016, 01:29 PM | #2 |
totally normal with the 2 way diffs in low speeds or u turns
06-06-2016, 01:54 PM | #5 |
2 ways are suppose rotate in the same direction and mine only rotates that small amount shown in the video in opposite directions before it stops. When I am driving the car it locks fine.
06-06-2016, 01:56 PM | #6 |
I have a nismo 2 way. It makes a lot of noise and locks aggressively. You can play with different fluids for more/less lock.
MRP Manufacturing |
06-06-2016, 06:57 PM | #9 |
i used to have a nismo two way and it would do that under slower speeds no throttle.. under throttle it would lock perfectly every time never had issues.. just a little sloppy
06-07-2016, 07:28 AM | #14 |
I believe FSM is 1.5
MRP Manufacturing |
