Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 04-20-2016, 01:19 PM   #1
Enjuku Racing
Trader Rating: (29)
Enjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to behold
Feedback Score: 29 reviews
Send a message via AIM to Enjuku Racing
Enjuku Racing - PLX Kiwi 3 OBDII Scan Tool
PLZ Kiwi 3 OBDII Scan Tool
Kiwi 3 is a plug and play automotive tool that connects to the onboard diagnostic port (OBDII / CAN), retrieves information from your car's computer, and wirelessly transmits to your smart phone, tablet, smart watch, or PC.
Compatible with 1996 and later vehicles Kiwi 3 monitors MPG, data log engine parameters, read/reset engine trouble codes, monitor real time engine performance, fuel efficiency, driving behavior and much more.
Easy as 1-2
Kiwi 3 is the next generation of OBDII adapters and no longer requires cumbersome bluetooth pairing or wifi configurations. Simply, plug and launch the app. Kiwi 3 does the rest!
Engine Diagnosis and Monitoring
Depending on the app and the vehicle's make and model Kiwi 3 can display:
Air flow (MAF)
Air intake temperature
Ambient air temperature
Barometric pressure
Catalytic converter temp
Coolant temperature
ECU voltage
Engine load
Engine timing
Evaporative purge
Fuel level
Fuel pressure
Intake pressure (MAP)
Long term fuel trims
OBD type
Oxygen sensor voltages
RPM
Short term fuel trims
Throttle position
Vehicle speed
Distance traveled since code cleared
Distance traveled with malfunction indicator
And more ...
The smallest, fastest, and most versatile OBD adapter yet Kiwi 3 is up to 4 times faster than the nearest competitor and uses ultra low power allowing you to leave your device installed permanently in your vehicle. Compatible with all standard OBDII protocols, Kiwi 3 installs in seconds. Firmware can be updated via Bluetooth and employs a nearly invisible design. When inserted into your OBDII port, Kiwi 3 sits just 0.68 inches thin making it the smallest and most discrete OBDII adapter.
Cross Platform Compatible
Kiwi 3 is the world's first true cross platform support compatible with iOS, Android, Windows, Mac, and Linux. Kiwi 3 allows for app developers to freely deploy without restrictions like the Apple Made for iPod (MFI) program. As a result, Kiwi3 is a simple and straight forward making it highly developer friendly.
Apps for All
To ensure a superior user experience we partnered with the world's most popular OBD app developers. Kiwi 3 is compatible with your favorite apps like DashCommand, Torque, Harry's Laptimer, and more!
Vehicle compatibility
*All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped.
In Stock and Ready to Ship!
$99.99
Office: 352-241-8399 / 1-888-SR20DET (772-0338)
YouTube.com/c/EnjukuRacingParts
http://www.enjukuracing.com
[email protected]
Enjuku Racing is offline   Reply With Quote
