Clean Zenki Sr20det with AC
S13 blacktop type x sr20det from jdm orlando
New iridium NGK plugs Battery relocated to trunk 2 gauge wiring New Optima Redtop battery Stock t25 turbo Stock e5 ecu New Hks wastegate actuator set at 13psi Cx racing FMIC kit with bov Isis thermo stat EXHAUST Isis elbow 3" downpipe Hks highpower exhaust Circuit racing poly exhaust bushings Cody Ace ac bracket kit All new napa/ gates serpentine belts Wiring specialties engine ,coil, and transmission harness Mobil1 synthetic motor oil change Redline gear fluid in the transmission New stainless steel clutch line New Walbro 255 lph fuel pump New slave cylinder New master cylinder New stock fuel filter New oem shifter bezel Apexi Intake New blower resistor oem Isis colder thermostat New Dual core aluminum radiator Silicone radiator hoses Color matched valve cover with hydrodipped skull pattern Oem valve cover gasket and spark plug seals Turbo oil return gasket replaced oem Aem wideband/boost failsafe gauge B&M short shifter Nismo shift knob Replaced hoses under intake manifold Replaced intake gaskets with oem Led license plate light Led dome light Led cluster lights 5k hids with wire harness and relay Has oem floor mats Interior is decently clean , rip on driver dr panel New nissan wiperblades New oem coolant temp sensor New oem radiator bushings New oem oxygen sensor New oem coilpack cover New oem knock sensor and subharness Isis powersteering pump pulley Powered by max coilovers bought new in august 2015 Varrstoen es2 18x9.5 225/40/18 nitto neo gen front and 18x10.5 255/40/18 rear 300zx rebuilt calipers with zinc plated slotted and vented rotors , stainless steel brake lines , and wagner thermoquiet pads. Car made 250whp on dyno and ran 13.8 in 1/4 at 102mph at pbir. J30 vlsd differential with redline oil New trans fluid done at nissan dealer 1/26/16 Car has ice cold ac its super reliable and my daily driver. Drove it to tampa and back from stuart,fl no issues past weekend and ive gone to orlando and miami numerous times Price is $8500 cash only Call or text (772)3539851 Have clean clear title in my name No low ballers [IMG] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Walter White; 02-08-2016 at 11:08 PM.. |
#6 |
Or post them per the fucking rules , lazy fucks in Florida
Www.PowerAutosports.com |
#11 |
Shoulda done that in the fucking first place, read the damn rules.
@hcr32love 400whp NEO R32 Sedan |
#13 |
95 240sx se model 5 lug , sun roof ,power windows and locks
ENGINE S13 blacktop type x sr20det from jdm orlando New NGK plugs Battery relocated to trunk 2 gauge wiring New Optima Redtop battery Stock t25 turbo Stock j4 ecu New Hks wastegate actuator set at 13psi Cx racing FMIC kit with bov Isis thermo stat EXHAUST Isis elbow 3" downpipe Hks highpower exhaust Circuit racing poly exhaust bushings Cody Ace ac bracket kit All new napa/ gates serpentine belts Wiring specialties engine ,coil, and transmission harness Mobil1 synthetic motor oil change Redline gear fluid in the transmission New Walbro 255 lph fuel pump New slave cylinder New stock fuel filter New oem shifter bezel Apexi Intake New blower resistor oem Isis colder thermostat New Aluminum dual core radiator Silicone radiator hoses Color matched valve cover with hydrodipped skull pattern Oem valve cover gasket and spark plug seals Turbo oil return gasket replaced Aem wideband/boost failsafe gauge B&M short shifter Nismo shift knob Replaced hoses under intake manifold Replaced intake gaskets with oem Led license plate light Led dome light Led cluster lights 5k hids with wire harness and relay Has oem floor mats Interior is decently clean , rip on driver dr panel Good bosch wiperblades New oem coolant temp sensor New oem radiator bushings New oem coilpack cover New oem knock sensor and subharness Isis powersteering pump pulley J30 vlsd differential with redline oil New Powered by max competetion Coilovers 18x9.5 front and 18x10.5 Varrstoen es2 225-40-18 front new nitto neogen and 255-40-18 rear tires good tread speed balanced Aem uego failsafe digital wideband/boost gauge Nrg hub Nrg quick release Momo steering wheel Real carbon fiber dash Windows tinted 5 percent Alpine headunit with iphone 6 compatibility, usb,bluetooth, aux . Pioneer speakers all around All original body panels on car ,has never been painted no bondo at all No abs $8500 Car runs great and AC is blows cold at 40 degrees! Powersteering also works. New 300zx front brake upgrade with rebuilt calipers, new drilled and slotted rotors (zinc plated dont rust) and wagner thermoquiet pads with stainless steel brake lines. Serious inquiries only with cash in hand (772)3539851 text or call ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
s14, sr20det, zenki |
