Old 01-13-2016, 11:57 PM   #1
salisch1
salisch1 is an unknown quantity at this point
Very bad cylinder misfire..
Car is a 1992 240sx s13 with a KA24DE, just got done with transmission swap and everything was fine the first day now the second day and its backfiring a lot. It backfires on every gear when decelerating and sometimes when accelerating. It also will take forever to start and sometimes wont if i dont give it gas. When it does start its a very rough idle. Any thought and or links to a similar post?
salisch1 is offline   Reply With Quote
Old 01-14-2016, 12:08 AM   #2
salisch1
Heres a video. https://www.youtube.com/watch?v=aDQZiG5wedo
Old 01-14-2016, 12:42 AM   #3
NoFlex
NoFlex is an unknown quantity at this point
have you checked timing?
NoFlex is offline   Reply With Quote
Old 01-14-2016, 12:55 AM   #4
salisch1
i checkedthe timing a few days ago and it was set correctly. could it change by itself in such little time?
Old 01-14-2016, 01:01 PM   #5
jedi03
Was it auto to manual swap or just new tranny?
Old 01-14-2016, 01:34 PM   #6
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Check your plugs to see if you're running too rich or something.
SoundEfx is offline   Reply With Quote
Old 01-14-2016, 01:56 PM   #7
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
Post MAF leak?
Crazyced is offline   Reply With Quote
Old 01-14-2016, 02:05 PM   #8
ultimateirving
ultimateirving's Avatar
Originally Posted by Crazyced View Post
Post MAF leak?
This,
Something is loose like a clamp, coupler or a hole in the vacuum system. Upon decel it's pulling vacuum like crazy.
Z32 with lq4 swap
Old 01-14-2016, 03:04 PM   #9
SoundEfx
SoundEfx's Avatar
But I thought a backfire is normally caused by a rich mixture and a post maf vacuum leak would cause a more of a lean mixture?
Educate me oh wise ones.
Old 01-14-2016, 03:14 PM   #10
salisch1
one of the plus was very very fouled and it smelled like gas on cylinder 1. I replaced all spark plugs just to be safe and I took it for a test drive. Still backfires but not nearly as much and not nearly as loud.
Old 01-14-2016, 03:15 PM   #11
salisch1
whole swap
Old 01-15-2016, 09:36 AM   #12
SoundEfx
SoundEfx's Avatar
I am assuming that when you say whole swap, you mean ecu and harness as well.
Change the spark plug wires as well and check to see if the injector(s) are leaking.
Old 01-15-2016, 06:34 PM   #13
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Sounds like a leaking injector
corkscrew is offline   Reply With Quote
Old 01-15-2016, 07:30 PM   #14
ultimateirving
Originally Posted by ultimateirving View Post
This,
I was driving today, and i just backfire in every gear on decel i think its just running rich by putting the engine under load... Is your MPG suffering ?
Z32 with lq4 swap
Old 01-16-2016, 12:05 AM   #15
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
sounds like a leaky injector,turn car on let it idle for a little bit, shut if off and leave the car over night allow it to sit. remove spark plugs in the morning (do not turn car on) if spark plugs are moist at the tip more than likely you have a leaky injector, if that shit is soaked more than likely your injector o-rings are busted.
S-Nation S13 is offline   Reply With Quote
Old 01-18-2016, 02:08 AM   #16
salisch1
thank you to every one to had helped. cylineder 1 injectors o ring actually melted and the casing came off and got stuck in the hole. this also caused me to ruin 2 spark plugs. seems like the answer is almost always leaky injector lol
Old 01-18-2016, 08:51 AM   #17
Crazyced
Crazyced's Avatar
I'm not entirely sure of the science behind it but I know carb motorcycles can backfire on decel and throttle shuts when running in lean conditions (cold temps, freeflow exhaust, badly adjusted carb, etc). Wouldn't be surprised if that was his issue as well.
EDIT: Basically the fuel mixture on decel is too lean to combust reliably every stroke so the mixture accumulates in the exhaust and eventually combust when the odd firing happens.
Old 01-18-2016, 10:50 AM   #18
Kingtal0n
Kingtal0n's Avatar
this post touches on a very good point/subject I want to elaborate with
On most engines, like the KA/SR/RB, there is a fuel cut when TPS goes to resting position above a specific RPM threshold. For the stand-alone ECU this is adjustable naturally, but for OEM ecu it is around 1400rpm, it depends on whether the A/C is on or not. Threshold for fuel cut is higher when A/C is on. This helps keep the engine from bogging as it returns to idle.
To paint a picture, you are driving in 4th gear for example, around 40mph, some rpm (say 2400rpm). Your throttle is slightly open for the cruise situation. Suddenly, you lift your foot from the gas pedal.
If you had an open downpipe, or any kind of non-silent exhaust system, there should almost always be one single pop as the final cylinder gets some but not quite enough fuel to burn at such a lean ratio, and this fuel enters the exhaust and makes a slight "POP" noise. The key to this, and the reason I am pointing it out, is that this POP noise only occurs ONE TIME. It signifies that the engine has entered a fuel cut mode, and that none of the injectors is leaking excess fuel. Next time you drive, pay attention when you lift your foot, there is always this one critical POP as the ecu pulls into it's fuel cut mode. Any extra POPPING is caused by fuel entering cylinders that should not be there (leaking injectors). Also note the exhaust system needs to be hot enough to burn the fuel (it might not pop on decell when cold). There is plenty of oxygen in an exhaust system when the car is in decell (the engine is turning but no fuel is going in, it is literally pumping your exhaust full of fresh air. In fact you could potentially free-air calibrate a wideband sensor by allowing the engine to decel during fuel cut, I do not recommend this but the literature on wideband sensors does mention this technique).
tinyurl.com/4l80er
ka24de, misfire, s13
