12-15-2015, 02:42 PM | #1 |
P2M Upgraded Nissan S13 S14 SR20DET Ignition Coil Packs Now Released!
P2M Nissan S13 S14 SR20DET (RWD) ignition coil pack set is a direct replacement over the factory unit with the following improved features:
- Strictly produced via TS16949 certified manufacturing facility - Top quality high insulation expoxy - Top quality high voltage di-electric resistant resin - 15% stronger spark output than factory unit - Increased winding and improved iron core - Dyno proven performance (+4rwhp / +5 ft lbs torque peak to peak) - Compatible with all aftermarket ignition box upgrade ** Dyno graph based on stock S13 SR20DET running stock 8-9psi (0.6bar) Can be ordered directly through our website or any P2M product distributors: http://www.phase2motortrend.com/prod...cp50f01-tt.htm
909-594-3619 Business Hours: Mon-Fri 10am-6pm (Pacific) email: [email protected] http://www.phase2motortrend.com |
12-15-2015, 07:23 PM | #2 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
count on me ordering a set of these soon! i am quite pleased with your throttle body velocity stack ring and the difference it made along with your side feed fuel rail (especially how nicely it installed). i look forward to running these in the near future!
12-15-2015, 07:43 PM | #4 |
Very nice, but pricey. How does it compare to the splitfire?
http://www.frsport.com/DIS-004-Direc...FUWVfgodzlcM9A |
12-15-2015, 07:44 PM | #5 |
Yes price is for a set of 4pcs
Sent from my SM-G928T using Tapatalk
12-15-2015, 07:45 PM | #6 | |
12-15-2015, 07:49 PM | #7 | |
Watch our release of our stage two ignition upgrade amplifier box next year 2016, it will work nicely with our existing coil packs and still end up cheaper than Splitfires. The stage two ignition box will be plug and play with Wiring Specialties built Pro harness. [emoji106] Sent from my SM-G928T using Tapatalk
12-15-2015, 08:45 PM | #9 | |
12-16-2015, 06:11 AM | #10 |
Between the price, increased performance, and lifetime warranty, I don't think I have a reason to buy from another vendor. You guys made this a totally awesome offering!
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S |
12-16-2015, 09:27 AM | #12 | |
12-20-2015, 08:16 PM | #15 |
Have you tested these with any sort of ignition amplifier? I'm currently running the HKS Twin Power on my SR with stock coil packs, haven't had an issue but these seem a little "fresher" and wouldn't mind ordering/installing these more for piece of mind.
12-20-2015, 10:59 PM | #16 | |
We will also be releasing our P2M plug and play amplifier for 2016 year which will work with our coil packs and stock coil packs, and will offer another ignition combo package for the amplifier + P2M coil packs combined.
12-20-2015, 11:19 PM | #17 |
Trader Rating: (18)
Feedback Score: 18 reviews
Again, great products from Phase 2.
Quality, price, and lifetime warranty!!! Will this be fine to use for people that already have Rom tune, PFC, standalone, etc. ? No need for retune, I'm guessing? |
12-20-2015, 11:54 PM | #18 |
No need for retune, maximize the ignition performance from your existing setup.
12-21-2015, 03:36 PM | #20 |
Price is a set of 4 pcs.
12-21-2015, 09:11 PM | #22 |
I guess we should mark it up higher then.
12-21-2015, 09:44 PM | #24 |
I think your order just came in. We will have it ship out tomorrow, thanks for your support.
12-22-2015, 07:08 PM | #26 |
More is coming for 2016.
02-03-2016, 03:55 AM | #27 |
Good bump
03-28-2016, 03:29 PM | #28 |
what do these ignition coil packs ohm out to as opposed to factory units? any info on dwell you can provide? where are they made? can they take the heat of drifting at 20psi? reviews and knowledge of this parts existence are lacking with its new item status. give us all a warm fuzzy about it and let the product go into back order for popularity sake.
1991 S13.5, 1993 Vert, 1998 180sx |
03-29-2016, 06:23 AM | #29 |
The coil packs were built within the same OHM as stock, however the increased in spark energy and consistency comes within the improved coil pack iron core inside the coil pack. The improvement is consistent spark performance over the weaker factory OEM Nissan coil pack which improves torque and HP power curve.
We've yet to come across any heat issue, but with our life time warranty for P2M products we got you covered if anything goes wrong.
