Old 10-09-2015, 11:02 AM   #1
LivelyZ
LivelyZ is an unknown quantity at this point
Coolant leak SR20
SR20.. I have a coolant leak from one of the hoses at the bottom of the block on the exhaust side.
By the looks of things previous owner knew about it and put a piece of plastic and wire over where it is leaking..
What size hose is that and is it a big job? where does the other end of the hose connect to? Seems to be leaking a lot.. puddle under the car if it sits, filled the radiator and reservoir , went for a drive, let the car sit overnight and it seems to be empty again
'97 sr20det swapped Kouki
previous: 94 Supra, 04 WRX
LivelyZ is offline   Reply With Quote
Old 10-09-2015, 11:49 AM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Are you sure that's a coolant line pictured on top? Looks like placement for a turbo oil return line. Factory oil return line also had heat insulation wraped and was twistwire secured, but your missing the metal clip shield thing that goes over the whole bit
At this point it seems to me you are leaking from a turbo coolant feed line or fitting(s), that freeze plug above it doesnt appear to be weeping or anything in the picture
OR
You drove through a swamp
zombiewolf513 is offline   Reply With Quote
Old 10-09-2015, 12:00 PM   #3
LivelyZ
OR
I wanted to believe it was.. First time working with this 240 and unfortunately I bought it swapped so not sure whats been done..
Exhaust side where would be a good spot to look for a leak? Take the heatsheild off the turbo and check fittings? Easiest way would be from underneath? or have to remove the exhaust manifold....
Old 10-09-2015, 12:30 PM   #4
ultimateirving
ultimateirving's Avatar
There is either a Turbo coolant hose that runs behind the head above the transmission bell housing that can leak, or the hose that goes from the turbo to the fitting on the block right underneath the exhaust manifold
Z32 with lq4 swap
Old 10-10-2015, 10:35 AM   #5
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Just have the engine running and get underneath the car to try and find it. That hose in your picture is the turbo oil return. And it is wrapped, from the factory, with heat shielding material.
Javi802 is offline   Reply With Quote
Old 10-31-2015, 05:02 PM   #6
jedi03
I say it's getting blown back from further forward...plus one that's the oil return, run it and look for leaks
Old 11-02-2015, 08:56 AM   #7
LivelyZ
yeah just crawled under it and it was coming off the turbo.. whats the easiest way to get to the coulant lines on the turbo? taking the heat shield off and going from the top or ?
Old 11-02-2015, 08:57 AM   #8
zombiewolf513
Any way you can possibly do it really. Probably from the bottom like how you took the original picture
coolant, leak, sr20
