09-09-2015, 08:24 AM | #1 |
S13 part out rocket bunny, tomei, fortune auto, bn sports, origin.
going to start this part out so let me know what you need!! Most parts are obo, and I may keep some things
Details on the car: 1990 hatch s13 Chassis has just over 200k Body: Full rocket bunny aero $900 obo Bn sports reverse mount hatch with rocket bunny wing -$SOLD Origin overs front and rear (I believe the fronts are 20mm and rear 30mm if I remember correctly) also the rear inner fenders have been cut and welded to fit bigger wheels so the overs aren't just for show. $150 per set - $ BOTH SETS SOLD Ab flug flush mount headlights - $SOLD Origin tails-$SOLD Ganadors style mirrors I am unsure if they are real -$SOLD Vis carbon good-$150 obo Engine: Blacktop s14 sr Tomei rocker arms stoppers Tomei 256 will sell the full motor no turbo, harness, injectors, it will include the transmission, fidanza light weight flywheel, and spec 4 puck- $1750 or will separate the motor from trans etc. Nismo 550cc injectors -$250 Tomei 7960 turbo-$800 obo R.y.o manifold- will go with motor or sell for $150 Megan dump $-75 Apexi exhaust -$SOLD RS enthalpy tuned ecu $400 Cx racing rad and dual fans $150 Sard fuel pressure regulator $125 Tomei spark plug garnish $95 Hks ssqv black series blow off $200 Suspension Gt spec front and rear strut bars $ 100 each- $SOLD Fortune auto 500 coils with swift springs $1000 obo $SOLD Work cr Kai rims in wmb finish 17x9 +15front and 18x9.5 + 12 rear with 10mm spacer $1500 obo Q45 rear end with z32 axle -$650 obo Solid subframe and diff bushings -$200 Q45 front brake set up rotors need to be turned -$SOLD Front 5 lug with spindles -$200? Obo Interior Grant steering wheel Pbm shifter Apexi boost gauge (light is broken) S gear oil temp gauge Also have an s gear oil pressure gauge uninstalled S14 front seats - $SOLD Has working ac with slight leak so doesn't get cold.. Supposedly made 320whp which I do believe the car is pretty quick Sound deadening removed and carpet reinstalled. Last edited by jk26; 01-14-2016 at 03:54 PM.. |
09-09-2015, 09:07 AM | #4 |
09-09-2015, 09:20 AM | #6 |
PBM Shifter price, please.
Also, you may want to put some prices up otherwise it may be locked.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
09-09-2015, 09:32 AM | #8 |
09-09-2015, 10:04 AM | #14 |
09-09-2015, 11:23 AM | #16 |
Is the SR a Kouki or a Zenki blacktop?
Do you have the Harness? To wire up the blacktop SR to the S13? If so, how much are you looking for delivered to 27518? Also looking for a CAS aswell. Scott. |
09-09-2015, 08:40 PM | #18 |
Looking for $250 obo on injectors
To my knowledge its an s14 zenki blacktop and I do have the harness. Most likely will sell the CAS with the motor. |
09-09-2015, 09:38 PM | #20 |
