Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Brakes
Old 07-28-2015, 04:22 PM   #1
PoorMans180SX
PoorMans180SX's Avatar
**WSRD Brake Line Relocation Kits!**
Our brake line relocation kits route under the factory crossmember, cleaning up the bay and making room for turbo setups. They're compatible with S13/Z31/Z32/Pathfinder master cylinders and are made in the USA! Teflon braided stainless line coated in a protective teflon outer shell means these are built to last! (Pictured with V1 High pressure power steering line).
Comes with all the fittings to connect your master cylinder to the caliper and rear brake line(s).
http://www.whalentuned.com/nissan-240sx.html
Zilvia price: $199 shipped! PM me to order!
Old 07-28-2015, 04:56 PM   #2
TheRealSy90
TheRealSy90's Avatar
Do you offer the lines from the front and rear calipers also? Or can you recommend a good brand for those of similar quality.
Such a good signature.
Old 07-28-2015, 05:14 PM   #3
PoorMans180SX
We don't currently offer the caliper lines, but we recommend and install Goodridge lines here at the shop on a variety of vehicles. We can get them both to you in the same box.
Old 07-29-2015, 06:14 AM   #4
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Nice !!!
Is it made to order? if so, what is turn around time?
ChaseBays took 391 weeks... LOL
Old 07-29-2015, 10:36 AM   #5
PoorMans180SX
Originally Posted by K_style View Post
Nice !!!
HAHA, they are made to order, but the maximum turn around time is four weeks. We usually get them done in two.
Old 07-29-2015, 06:50 PM   #6
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
Damn I should have waiting till this special to order mine.
Freddy is offline   Reply With Quote
Old 07-29-2015, 11:34 PM   #7
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
Price on these brake lines and also the clutch line (from master to slave) shipped to 91042 lmk
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 07-30-2015, 12:56 AM   #8
Zero-Offset
Zero-Offset's Avatar
Zero-Offset is an unknown quantity at this point
installed my kit finally, went in fantastic! more than enough line and everything went together smoothly. kit is easy to figure out. would support Whalen again!!!
G O O D ★ V I B E S
http://instagram.com/lowrize_
Zero-Offset is offline   Reply With Quote
Old 07-30-2015, 08:24 AM   #9
PoorMans180SX
You have a PM good sir.
I'll shoot you a quote later today.
Thanks for the kind words! Good to hear!
Old 08-07-2015, 07:09 AM   #10
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
do you have before and after shots of engine bay?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 08-07-2015, 03:11 PM   #11
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Is the fitting with the o-ring seal that goes into the high pressure side of the rack an off the shelf item or is it custom made? I've read that the off the shelf fittings do not correctly seal because they are slightly short and what people have done is machine it to get the o-ring to fit correctly.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 08-10-2015, 10:24 AM   #12
PoorMans180SX
I only have after shots unfortunately!
We use off-the-shelf fittings, but we've never had an issue with them leaking. I feel like people are often afraid to tighten them all the way.
Old 08-10-2015, 06:07 PM   #13
Halfamazing
Halfamazing's Avatar
Halfamazing is an unknown quantity at this point
I know this says s13,z31,z32 but... I have a s14 master and I need this kit. Would it work or can you make me one?
Halfamazing is offline   Reply With Quote
Old 08-11-2015, 01:01 PM   #14
PoorMans180SX
This kit won't work with a S14 master. If you were local, we could make you a kit, but I don't feel comfortable building a kit without the ability to test fit it. I've been trying to get a S14 in here for a while now, but so far haven't been able to. When we do, we'll build a kit and post it up!
