Old 05-11-2015, 08:22 PM   #1
Illmatic_s13
Illmatic_s13 is an unknown quantity at this point
Question 13b renesis (msp) into s13?
Got a crazy idea tonight. So I know that people have put 13b's into 240's before, but I've never seen the newer engines put in. Usually the 90's models.. Has anyone ever dropped in the renesis motor? If so can someone help me find like a write up for the swap? (Don't tell me "don't do it, waste of time, etc".. I'm just wondering out of curiosity. It seems like a cool swap.) thanks.
-jared
Illmatic_s13 is offline   Reply With Quote
Old 05-12-2015, 02:07 AM   #2
Croustibat
It is a crappy engine, hence why no one uses it. You could turbo one, but in the end it will cost you more than building a 600HP sr20.
Old 05-12-2015, 02:38 AM   #3
yzrider450f
yzrider450f's Avatar
yzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of light
yzrider450f is offline   Reply With Quote
Old 05-12-2015, 06:42 AM   #4
Illmatic_s13
Let's say I already bought the whole set (engine, trans, harness, ecu).. Any advice on how to drop it in? I'm not worried about wiring at this point in time.
Old 05-12-2015, 07:23 AM   #5
Croustibat
Ok, let's try it another way.
If you have already bought it, you can now sell it again and cut your losses before they aggravates. Or just bin the whole lot before spending time and 10K on labor and custom parts, only to end up with a fuel & oil hungry unreliable engine and trans that has even less torque than a honda.
Old 05-12-2015, 07:30 AM   #6
slidewayz240
slidewayz240 is an unknown quantity at this point
Im with these guys. I love rotary motors, but the renesis is the worst thing I have ever had to deal with. Get rid of it as quick as you possibly can. People with rx8s will pay some decent money for a motor set in good shape since theirs is most likely blown.
slidewayz240 is offline   Reply With Quote
Old 05-12-2015, 08:05 AM   #7
g14novak
g14novak is an unknown quantity at this point
Only reason to ever go/stay renesis engine is if its in an rx8 and your trying to stay in a lower class of SCCa or NASA with an unmodified engine to be competitive on the scoreboards. When you engine swap the S13, that defeats the purpose, you get put in a high their modified class. If you want to go 13b, get a 13b-TT Cosmo block, put a FD auto rear iron on it, run a turbo 2 transmission with FD auto bellhousing and FD pull type clutch setup. Then you just need an EMS like megasquirt, haltech, or microtech to run it. You'll be at ~350whp stock porting and stock twins and still less invest than the stock renesis swap that only makes ~170-180 if your lucky.
The renesis really isn't worth it. You'll get mean mugged from the 240 community for putting a rotary in the 240 and mean mugged from the rotary community for putting a crap engine in your car.
g14novak is offline   Reply With Quote
Old 05-12-2015, 07:00 PM   #8
Illmatic_s13
Again, not trying to piss anyone off by my stubbornness, but I really want to do this. And if it all blows up in my face, you can tell me "I told you so".. So please, any ideas on how I would go about bolting it in? Obviously custom motor mounts, trans xmember, and drive shaft, but is that basically it? For wiring I'd probably go megasquirt and then just find a way to connect it to the body harness.
Old 05-12-2015, 07:08 PM   #9
Illmatic_s13
Alright so, if I go 13b-tt, don't use the stock trans or clutch?
Old 05-12-2015, 07:56 PM   #10
zach3904
zach3904 is an unknown quantity at this point
You're very much over simplifying what'll be needed. The cost will run away in the details. Radiator hoses, electric fans/controller, heater hoses, power steering lines, custom exhaust manifold, likely a custom oil pan, possible tranny tunnel modification, shifter placement, possible re-routing of the steering linkage, throttle cable, clutch line, brake booster vacuum line, battery relocation, custom intake piping, etc. That's all before you get to the potential nightmare of wiring.
Not trying to dissuade you, but you really can't think of this as being anywhere near a bolt-in affair and the ease-of-install will be all in the details/planning/preparation. The hurdles you don't see will likely be the most frustrating, costly and time consuming. Fully consider and acknowledge what you're getting into vs. reducing the project to the obvious and telling yourself it'll be a piece of cake.
That said, anything can be done and I wish you the best if you go for it! Could be pretty rad and no doubt unique.
zach3904 is offline   Reply With Quote
Old 05-12-2015, 08:17 PM   #11
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
if you have to ask, you wont be able to pull it off. If you still want to give it a try, you're gonna have to get your hands dirty: Strip the chassis, stick the new powerplant in, make it fit aligning the trans shifter and leveling the engine (this could mean cutting and welding parts of the chassis), mount it securely, start working out the details. That simple, and it applies for almost any swap.
feito is offline   Reply With Quote
Old 05-13-2015, 10:07 AM   #12
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Dude. Stop thinking with your dick and use your brain. This is dumb. There is no support for this, no help and no reason to do it.
S13 swaps nickel and dime you to death, then you want to add on rotary issues, then you want to try and figure out out to get the electronics from one manufacturer to another and not mention the dimensions of the above mentioned? You're an idiot.
Some people here are trying to be nice about it, but stop being stubborn and be smart.
Even swapping it into a FC isn't common.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 05-13-2015, 11:49 AM   #13
Clutch Dog
Clutch Dog's Avatar
Clutch Dog is an unknown quantity at this point
Send a message via AIM to Clutch Dog
Coming from the rotary world, there is a reason FC guys stick to 13B's. anyone who messes with the Renesis motor just uses the housing on the 13B endplates for the exhaust ports. there's a bigger aftermarket for the 13B and more a proven design, not to mention the cost per part between a 13B and Ren.
So yes it would be possible to swap a rotary into a s13. a) if you wanted to do that why not get an FC since they have the chassis that was build for that motor and will probably handle better because of it.
b) if you want to do something different why not source out something that would be a logical upgrade. even a vg30 would be something better then a 13B as far as torque and power output c) who gave you internet access.
The big issue with the Ren motor is that like the VQ is uses a CAN system that unless you completely redo the wiring harness for your megasquirt you'll be chasing weird wires and signals till it runs right, even then rotaries use a specially designed ecu and fuel map system it'll be hard for you to get that all in without hurting your motor. assuming you already have the engine and trans then good luck to you.
Mad Moody Science LLC In house is the best way.
Clutch Dog is offline   Reply With Quote
Old 05-16-2015, 07:11 AM   #14
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
I've been wanting to do it mainly waiting on funds. Most likely would get a Cosmo 13b-re or s5 fc 13b-t with a T2 tranns. instead of a FD 13b-TT and tranns. (engine mounts are directly in front of the tranns would require a custom subframe to do right). It's hard to info on fitment without actually looking at parts. Thankfully there's a huge rotary specialist shop local so that will make things a lot easier.
foreverdeath is offline   Reply With Quote
Old 06-09-2016, 04:31 PM   #15
shahee1
shahee1 is an unknown quantity at this point
Sooooooo ummmmm ... Thats it??? No more talks??? No Progress???
shahee1 is offline   Reply With Quote
Old 06-09-2016, 04:35 PM   #16
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
swapping a Renesis motor into an S-Chassis is about as useless as a dick flavored lollipop. seriously, its like guys swapping b-series or k-series motors into s-chassis. the Renesis is a giant waste of time and money... if you REALLY have to swap a rotary into an s-chassis, use one from an FC/FD, at least theyre less prone to issues when setup and tuned right!
Old 06-10-2016, 05:37 AM   #17
Croustibat
You really expected something out of this thread ?
Old 06-10-2016, 07:08 AM   #18
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
k24s are cool as shit i would go K in a s chassis my buddy went K24 in his NB and its gonna be monster street car
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 06-10-2016, 09:49 AM   #19
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Old 06-10-2016, 10:16 AM   #20
RB25GUY
RB25GUY's Avatar
would i do a K before a ren motor, most definitely. Would i go out of my way to do a K series in a S chassis, no...... but ive seen nothing but potential out of boosted k series motors more reliable than sr's, half the price SR20vdet and with cams and minor head work not bottom end shit needed will rev to 9k all day.... but its pointless you are right dori i love my RB to much to ditch it for anything else...
Old 06-11-2016, 10:41 AM   #21
S13-Dreams
S13-Dreams's Avatar
S13-Dreams is an unknown quantity at this point
-Jared if you would happen to be "jared420sx" or whatever your other name is, please stop asking is anyone has swapped "non LS or Nissan motor into S chassis" Google it or Put that shit in and tell us how it goes.
Sent from my SM-J320VPP using Tapatalk
"The SE with the removeable top!" -random black guy at a gas station.
S13-Dreams is offline   Reply With Quote
Old 06-11-2016, 11:57 AM   #22
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
exactly
Old 06-11-2016, 01:58 PM   #23
boost
boost is on a distinguished road
http://www.youtube.com/watch?v=vHDX78z5V6s
boost is offline   Reply With Quote
Old 06-18-2016, 12:12 AM   #24
!Zar!
!Zar!'s Avatar
An F20 swapped S13 would be so rad.
13b, rotary, s13, swap
