Old 03-22-2015, 07:34 PM   #1
MitchP
MitchP is an unknown quantity at this point
RB Socal Garage Clean Out RB25DET/S13 - Clutch, Coils, CAS, Turbo, Arms, 044's
Hi everyone, doing some garage clean up and have some RB25DET/S13 parts for sale.
Located in Gardena, CA and I am willing to do a deal on pricing if you want multiple parts and will consider REASONABLE counter offers. Would prefer pickup for cash but also willing to do shipping & Paypal for added $$$. PM me or text/call 310-753-583seven if you are interested.
Thanks for looking!
Adjustable rear lower control arms for S13. Brand new but unknown brand - $250 for pair.
RB25DET S1 Coil Packs - $100 & RB25DET S1 Hitachi (no black button) Cam Angle Sensor (CAS) - $50
Brand New Bosch "044" Fuel Pumps. Genuine Bosch, purchased from Pegasus Racing - $150 each
Low Mileage Stock RB25DET S1 Turbo w/ compressor and O2 elbow - $200
Low Mileage Stock RB25DET Clutch, Pressure Plate, and Flywheel - $150
MitchP is offline   Reply With Quote
Old 03-23-2015, 01:44 AM   #2
rhd_sr
rhd_sr is an unknown quantity at this point
Would you sell flywheel seperate?
rhd_sr is offline   Reply With Quote
Old 03-23-2015, 08:44 AM   #3
TheRealSy90
TheRealSy90's Avatar
What fittings do the bosch pumps have installed in them?
Such a good signature.
Old 03-23-2015, 05:30 PM   #4
MitchP
@rhd_sr
Flywheel, clutch disk, and pressure plate will be sold as a group, sorry. (In case they don't sell, I still have complete backup setup for my OS Giken twin plate if the need arises)
@TheRealSy90
The pump itself has an inlet of M18 x 1.5 and outlet outlet M12 x1.5 and requires copper washer or O-ring for whatever adapter (-AN, etc...) you use.
These pumps are the OEM replacement pumps for Porsche 993 GT2's so they come with the factory banjo bolt/check valve fitting on the outlet for those cars which you can remove and replace with an -AN adaptor or whatever.
More info can be found with a quick Google search of "Bosch 044"
Old 03-25-2015, 06:03 PM   #5
MitchP
Bumpity Bump
Bumpity Bump
Old 03-26-2015, 08:44 AM   #6
TheRealSy90
Cool, I belive I would have to convert both fittings to barb fittings to use with my fuel lines. That your best price shipped to 85364?
Old 03-26-2015, 10:30 AM   #7
LeaS13Zenki
LeaS13Zenki's Avatar
LeaS13Zenki is an unknown quantity at this point
Any shaft play on that turbo? what was the mileage?
LeaS13Zenki is offline   Reply With Quote
Old 03-27-2015, 06:14 PM   #8
MitchP
@ TheRealSy90, PM'd you
@ LeaS13Zenki, Shaft play is minimal, less than 0.010", so about as good as you're gonna get with a used plain bearing turbo.
I don't know exactly mileage, but guessing 10-30k miles. It is off the cleanest used JDM engine I've ever some across out of 100's I've seen - no carbon build up on intake ports, no oil staining under valve covers, etc... which is why I bought it vs. a typical RB25DET.
I'm in Gardena so LMK if you want to stop and take a look for yourself. Will be around this evening and weekend.
Old 03-30-2015, 02:35 PM   #9
MitchP
One Bosch pump sold, one left.
Also, willing to sell the flywheel separately from the clutch disk & pressure plate.
Old 04-02-2015, 06:23 PM   #10
MitchP
Bump it up!
Old 04-12-2015, 06:29 PM   #11
MitchP
El Bumpo, still available
clutch, coils, rb25det, s13, turbo
