![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
![]() NEW PRICE $2000 shipped to continental US
The bad: has a top end noise, the shop it's at told me it's the lifters, I'm just done dealing with this engine. History: was stock drove it for about a year, spun a bearing having it tuned, was rebuilt with bc rods cp Pistons, bc 264/264 cams, acl bearings, it drove for 1300 miles and spun a bearing again, just got done having it rebuilt again, some new parts, currently has under a mile on it. full list of parts: S14 zenki sr20det engine and trans All sensors, all accessories, coil packs, igniter, ratty harness but works Cp Pistons Bc rods New remanufactured stock crank with matched acl bearings as close to stock clearance as possible New bc valves, new valve guides and seals Bc 264/264 cams Brand New dynatec lifters(supposedly bad) Bc springs and ti retainers New Apexi head gasket New oem oil pump New timing chain full kit New gaskets where applicable five-o 750cc injectors Spec street flywheel Will not come with turbo or exhaust manifold, clutch, or ecu By disconnecting the coil packs one by one the sound does not go away, which is another good sign that it's not a bearing, also the oil is immaculate no metal or anything, it runs and drives, I drove it around the block, I just don't think it sounds right and I don't trust it. The car is located at a shop in Des Moines Iowa if you would like to hear it in person I will post a link to a video of it running. I'm sure there are gear heads on here who can probably get this thing running like a top. Call or text preferred 515-249-5146 John
![]() Last edited by QuickSpoolSR; 04-06-2015 at 10:07 AM.. |
#11 |
![]() Join Date: Aug 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Throw it on ebay, for BIN at 2300. Someone will buy it if you can get a freighter to ship easily.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
built, s14, sr20det, swap |
