Old 03-08-2015, 02:24 PM   #1
my240issex
my240issex is an unknown quantity at this point
RB RB25 S2 Built Longblock
Part List Rb25/S2 01/18/14 #006
Series 2 RB25DET Block (0 Miles)
-Honed and Hot Tanked
-Over $1,000 in Polydyn oil shedding and friction
coatings (Block, Pistons, Timing gears, etc.)
-ACL Bearings Main/Rod
-ARP Main Studs
-ARP Rod Bolts
-10an Block Fittings
-New OEM oil pan w/10AN Bung
-New oil pump (Clearanced for High rpms)
-New water pump
-Rb26 water pump pulley(Remove if not installing aftermarket alt setup)
-ARP Head Studs
-3 Angle Valve Job W/new seals
-HKS Step 1 Cams
-Cometic head gasket
-Tomei Oil Restrictor
-Head Drain kit
-Ngk Spark Plugs
-Nismo Timing Belt (Run Time Previous build)
-New Timing Belt Tensioner
-Cometic Gasket Kit
-Raw Brokerage Exhaust Stud Kit
-Raw Brokerage Oil Filter Stud
-Raw Brokerage Turbo AN Fittings OIL/WATER
-PBM Filter Adapter
-OEM Thermastat
All Parts Have 0 Miles, Torqued to spec per Manufacture requirements.
Engine Work Done by Power Fab Houston, TX
Price is set at 3600 SHIPPED within the intercontinental US, FEES INCLUDED!
questions, pm me, or text me 3126369394
my240issex is offline   Reply With Quote
Old 03-18-2015, 01:49 AM   #2
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
Pmed youuuuu
Nibras is offline   Reply With Quote
Old 03-18-2015, 08:18 PM   #3
my240issex
Bumppppppppppppittyy
Old 03-21-2015, 11:34 AM   #4
dftsilvia
dftsilvia's Avatar
dftsilvia is on the path to ruindftsilvia is on the path to ruin
all that work and you didn't install an extended crank collar?
dftsilvia is offline   Reply With Quote
Old 04-09-2015, 12:03 AM   #5
my240issex
tomei oil restrictor.....
same thing but of a better brand.
Old 04-12-2015, 05:45 PM   #6
my240issex
Bunpityyy bump
Old 04-16-2015, 07:02 PM   #7
my240issex
uppppoppppppppppppppppppopopopopp
Old 04-18-2015, 01:19 PM   #8
my240issex
lets get this thing sold. taking offers. pm me.
Old 04-20-2015, 09:53 AM   #9
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
oil restrictor is this
http://www.ebay.com/itm/Tomei-191071...a31f18&vxp=mtr
not a crank collar
supersayianjim is offline   Reply With Quote
Old 04-22-2015, 04:04 PM   #10
my240issex
to be honest, they both serve the same function, preventing excessive buildup of oil in the head. Both of them serve the same purpose ��. Have a nice day everyone. Bump!
Old 04-23-2015, 07:43 PM   #11
supersayianjim
UMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnNO!!!
the crank collar is needed because the contact area on the oil pump needs to be increased or you will have a oil pump failure during high rpms!!!
2 totally different issues, not busting ur balls but please be informed! good day!
Old 04-23-2015, 09:20 PM   #12
serah31500
Trader Rating: (18)
serah31500 is an unknown quantity at this point
Feedback Score: 18 reviews
Nice buildup of the engine but yes totally different issues going on there buyer would have to tear it all down again to get the crank machined for the collar then this engine will be totally legit glws
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO.
serah31500 is offline   Reply With Quote
Old 04-28-2015, 10:18 AM   #13
my240issex
3200 shipped. bumppp need it gone
Old 07-06-2015, 01:00 PM   #14
my240issex
3000 shipped
Old 08-01-2015, 02:57 AM   #15
my240issex
2800 shipped. Bump
Old 09-02-2015, 12:39 AM   #16
my240issex
bumpppppppppppppppppppppppppp
Old 10-17-2015, 06:17 PM   #17
j2fast
j2fast is an unknown quantity at this point
Send a message via AIM to j2fast
What compression is the pistons and brand of Pistons and rods
www.j2fastmotorsports.com
j2fast is offline   Reply With Quote
Old 10-28-2015, 12:56 PM   #18
my240issex
oem polydon coated
Old 10-28-2015, 01:26 PM   #19
j2fast
That's pretty pricey for oem motor without the crank collar
Old 10-28-2015, 02:58 PM   #20
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Send a message via AIM to Mitsubayati
Pictures of the work done and the final "as shipped" product would be helpful to your sale.
Technically, the crank collar mod is to defeat the issue of oil pump gear damage. Since the OEM collar does not fully cover the whole surface area of the oil pump drive and there is play, abrupt motion (i.e. clutch kicks, instant accelearation, etc.) will hit the drive on the oil pump and weaken it eventually causing it to crack and no longer function.
Installing oil restrictors does not fix the crank collar issue and if he has a head drain kit, restrictors would be doing more than what is necessary. On top of that, restrictors won't necessarily fix issues with the RB. If you don't know how to set it up, you might cause more problems. He should have done a crank collar, but running no aftermarket restrictors on this build is perfectly fine.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 12-27-2015, 02:22 AM   #21
my240issex
bumpppppooo
Old 12-27-2015, 08:43 PM   #22
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
I decided on no restricter and I blocked one oil port on the block. Crank collar with spool import gears and I'm seeing 8 bar pressure with about 15w40. That's on break in
smoked240 is offline   Reply With Quote
Old 01-02-2016, 01:09 PM   #23
Chief 1402
Chief 1402 is an unknown quantity at this point
Pictures?
Msglength
Chief 1402 is offline   Reply With Quote
built, longblock, motor, rb25, rb26
