07-28-2004, 07:33 PM | #1 |
Steering Rack Bushings...
Anyone swap theirs?
SCC can't say enough about the difference it made on project STi and for all the added crispness, there is no added harshness. Lately my steering feels sluggish at turn in (doesn't help that I just test drove an Evo) and similar symptoms to what SCC described. So has anyone upgraded thir sterering rack bushings? Was it a worthwhile mod? How hard was it to do? Sounds like an easy cheap mod.
Steve 93 240sx FB currently very clean and for sale |
07-28-2004, 07:52 PM | #2 |
Energy Suspension Z32 steering rack bushings, cost about $12. Install is simple, but the left hand side one may be a tad dificult to slide into position. Can't fairly evaluate the diference it made because the stock old ones i swapped out were really bad, i.e. letting the rack slide side to side about half an inch. After installation of the bushings the stiffness hastened my tie rods demise. so swapped those soon after as well.
07-28-2004, 09:38 PM | #4 |
ype
i bought my ES for 8 bucks for the pair at the shop in LBC...i forget the name, they sell ES and you can get the number thru ES if you cal them for a shop in LBC..damn i forget the name!! i wanna say team C or team 8 team something i think.. |
07-28-2004, 10:19 PM | #5 |
Its cake...4 bolts, slide old ones out, slide new ones in. It felt a lot better, but I did LCA bushings at the same time so I am not sure which contributed the most (and my rack bushings were in decent shape). I replaced the tc rod bushings with whiteline bushings about a year ago; those made more of an impact than steering rack bushings and LCA combined. Rear subframe bushings also made a huge difference...the car feels much more stable while cornering and seems to settle into turns more quickly. Those add ride harshness, though.
91 SE |
07-28-2004, 10:48 PM | #6 |
OMNOMNOMNOM
Steve, I know its a big problem with Scoobies and their steering rack bushings. It fix's the nasty bump steer that is prevalent in most scoobies (Impreza's). We are going to order a set for the scooby once we get some $, plus if everyone is saying there this cheap for the 240 ones then why not. Bump steer is the devil! I might as well get them while I am ditching the PS & HICAS.
07-28-2004, 11:09 PM | #7 | |
i changed it when i changed my steering rack to hicas as well as all my other suspension pieces, coilovers, pillowball tension rods, pillowball tie rod ends... so i really can't tell the difference... |
