Old 12-15-2014, 12:16 PM   #1
hastyk
hastyk is an unknown quantity at this point
will my car run 14 seconds?
I'm not usually much of a bench racer...but this seemed interesting-my buddy just bought a new scion fr-so (not supercharged). Online specs say it's about a 14.9 second car...also it says the stock 93 240sx is a 16.1 second car. I just rebuilt my motor and haven't installed it yet.
My mods:
- Sohc pistons for a little higher compression
- 98 model head with 3 angle valve job
- Port matched intake with butterflies removed
- msd blaster 2 coil
- walbro 255 lph fuel pump
- 4-2-1 header with 3 inch exhaust
- egr block-off plate
- electric fans
- no a/c
- no p/s
- removed charcoal canister
- adjustable fuel pressure regulator (can someone tell me the ideal setting for it? It was on the car when I bought it)
- stage 3 6-puck clutch
- 1.2" drop springs
- kosei r-seneka wheels with 215s out back
- poly mounts
Do you guys think that this will get me into maybe the mid 14s? I know gains are a lot harder to get on a N/A motor. Thanks for any input!
Kevin
hastyk is offline
Old 12-15-2014, 12:47 PM   #2
omgosh
omgosh is an unknown quantity at this point
Finding the answer to this question is your job, at a 1/4 mile race track. lol
omgosh is offline
Old 12-15-2014, 12:48 PM   #3
hastyk
My car is not yet together or we would have already raced and this thread would have never been made. Thanks though.
hastyk is offline
Old 12-15-2014, 12:55 PM   #4
EJ8 944
EJ8 944's Avatar
EJ8 944 is an unknown quantity at this point
EJ8 944 is offline
Old 12-15-2014, 12:58 PM   #5
hastyk
Really? You find a thread just to bash? I wanna grow up to be just like you guys one day...
hastyk is offline
Old 12-15-2014, 01:42 PM   #6
silviaks2nr
silviaks2nr's Avatar
It's going to be a mighty boring race either way.
Keep it on the strip please.
silviaks2nr is offline
Old 12-15-2014, 01:55 PM   #7
mickluvinnz33
mickluvinnz33's Avatar
mickluvinnz33 is an unknown quantity at this point
nice mods. update when you do track it.
mickluvinnz33 is offline
Old 12-15-2014, 02:51 PM   #8
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
A lot of it has to do with your driving skills,suspension setup and most importantly what tires you have.but with yours parts list I don't see a massive whp gains to make a massive difference in your 1/4mile to a stock ka24de.
Instagram username:angelmkiv
angel mkiv is offline
Old 12-15-2014, 03:27 PM   #9
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
Adj fuel pressure reg and high flow fuel pump with stock injectors?
Now that you're a bench racer you can make better guesstimates with this
http://robrobinette.com/et.htm
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline
Old 12-15-2014, 04:52 PM   #10
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Ummm... so when did Georgia become part of Florida?
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Z_Spool is offline
Old 12-15-2014, 05:58 PM   #11
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Doesn't matter. Both cars are slow as hell. Trying to extracting real power from an N/A KA is pretty high on the list of collossal wastes of time.
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline
Old 12-15-2014, 06:02 PM   #12
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
I say no, you won't be able to win the FRS unless you totally strip out your car. You may stand a chance! Then again paper is one thing and actually racing is a whole other thing. Let the driving do the talking.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline
Old 12-15-2014, 07:48 PM   #13
zurud
zurud is an unknown quantity at this point
Nnnnnnnnnnoooooooooooooooooooo
zurud is offline
Old 12-15-2014, 07:58 PM   #14
hastyk
Thanks guys! Just wanted to know where I stood!
hastyk is offline
Old 12-15-2014, 07:59 PM   #15
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
"not supercharged" lol. You'd probably run 17's
feito is offline
clutch, fuel pump, ka24de, race, scion
