Old 08-09-2014, 11:42 PM   #1
JDMBart
Banned from the Marketplace
Trader Rating: (-1)
JDMBart is an unknown quantity at this point
Feedback Score: -1 reviews
Engine Died, No Spark HELP!
s13 ka24de I was driving down the street and suddenly the engine turned off. The car rolled to a stop and I have not been able to get it started since. It cranks and I am getting fuel but no spark. Where should I start?
All fuses and relays have been examined and are working.
JDMBart is offline   Reply With Quote
Old 08-09-2014, 11:58 PM   #2
J3123MY
J3123MY is an unknown quantity at this point
did you check the distributor and ignition module?
J3123MY is offline   Reply With Quote
Old 08-10-2014, 12:45 AM   #3
AZRB20
AZRB20's Avatar
AZRB20 is an unknown quantity at this point
You prob have a dead dizzy, mine died randomly. Replaced it and issue resolved.
AZRB20 is offline   Reply With Quote
Old 08-10-2014, 02:37 AM   #4
crossway
crossway is an unknown quantity at this point
I agree check or replace the dizzy. Once there is no spark engine will surely not run.
crossway is offline   Reply With Quote
Old 08-10-2014, 09:10 AM   #5
JDMBart
Trader Rating: (-1)
Alright I'm going to swap out the ecu today and if that doesn't work then I will replace the dizzy. Fingers crossed
Old 08-10-2014, 06:55 PM   #6
JDMBart
Trader Rating: (-1)
So I swapped in a known working dizzy and still nothing :-( what should I try next guys
Old 08-10-2014, 07:03 PM   #7
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
There are a ground wires by the Lhd master cylinder, two ground wires should be connected on the head right under the valve cover by the master cylinder. Since your car is a rhd, then its on the other side. That had happened to me a while back and that was the issue.
Also check the ground wire connection on the ignition coil and make sure its good. Could be a bad coil.
You can sleep in your car, but you can't drive your house.
No 240.. No id is offline   Reply With Quote
Old 08-10-2014, 07:04 PM   #8
JDMBart
Trader Rating: (-1)
Thank you!
Old 08-10-2014, 08:14 PM   #9
JDMBart
Trader Rating: (-1)
forgot to add,
I am not getting fuel or spark. The fuel pump primes but it does not go to the engine, I cant smell any fuel no matter how much I crank it
Old 08-10-2014, 11:26 PM   #10
l adam l
l adam l's Avatar
l adam l is an unknown quantity at this point
pull off feed line on fuel rail and turn ignition on...make sure you have two people and something to catch the fuel in. if you're getting fuel to the rail...then go from there.
l adam l is offline   Reply With Quote
Old 08-11-2014, 06:27 PM   #11
crossway
It might be a busted fuel regulator that is why you are not getting any fuel upon priming. But about not having spark. It can only be within the ignition system.
Old 08-11-2014, 07:37 PM   #12
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
What you should have done before anything major is replaced the ignition coil.
Swap it out and see what happens.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 08-12-2014, 12:01 PM   #13
JDMBart
Trader Rating: (-1)
Just picked up an Sr20. Problem solved ☺
Old 08-12-2014, 06:46 PM   #14
crossway
A simple problem turned into a engine swap. Anyway enjoy your new engine.
Old 08-13-2014, 12:32 PM   #15
JDMBart
Trader Rating: (-1)
well i think it was a ground or something, i will find it while pulling the motor. The dual cam in it now is going into the donor car I justed picked up that has the sr20. Will update build thread shortly
Old 08-13-2014, 02:44 PM   #16
PowerDrifter
PowerDrifter is an unknown quantity at this point
actually you just got a whole new set of problems
PowerDrifter is offline   Reply With Quote
engine, ka24de, no spark, stall, start
