Old 08-02-2014, 12:29 PM   #1
wheresmycoupe
wheresmycoupe is an unknown quantity at this point
s13 Need help with stalling !!!
So I'm having an issue where my car almost stalls coming to a stop. It drops down to about 500 rpms sometimes lower and The oil light flashes. Occasionally while driving my cel will blink 2 times at most. The temps have been to 100 Celsius during normal driving.
Set up is red top Sr With 550 cc inj. 50 trim .48ar. Power fc.
However my tune is for 550 ' s and a 50 trim .63 ar. I blew the turbo so the .48ar is just a temp solution until mine is finished being rebuilt. Idiotic I know.
Could that be my problem^^^ or could be something els like a bad tps and the oil light flashing is just cause the pressure is low when the cars about to stall?
wheresmycoupe is offline   Reply With Quote
Old 08-02-2014, 01:36 PM   #2
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
Did you check the oil? There's a reason it is flashing .
Maf or iacv?
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 08-02-2014, 03:53 PM   #3
wheresmycoupe
Yea oil level is fine no leaks not burning any. I'm running a map sensor
I did not check the iacv.
Old 08-02-2014, 05:13 PM   #4
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Boost leak test it. You could simply have a vacuum line that's either not on or completely unplugged
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 08-03-2014, 10:54 AM   #5
wheresmycoupe
I'm going to boost leak test it today. I also forgot to mention there's a weird vibrating/clanking noise when I hold the gas steady at about 3k. Not during acceleration or deceleration
Old 08-04-2014, 12:25 AM   #6
wheresmycoupe
Update vacuum pressure is fine no leaks.
Clanking noise only happens when throttle is held at content speed. Not during boost or idling.
Almos t sounds like it's coming from the timing chain area...
Old 08-04-2014, 07:51 AM   #7
rpierce
rpierce's Avatar
rpierce is an unknown quantity at this point
Sounds like the side effects of an atmospheric BOV on a MAF car. It almost seems like it happens more often with the Greddy type BOV's too.
It annoyed me so I just used a radiator hose to recirculate the BOV back into the intake and it runs fantastic now.
rpierce is offline   Reply With Quote
50 trim, 550 injectors, help a kid out, s13, sr20det
